Why no whine?
The only thing I miss from my 3.0 is the turbine like whine that it used to make. Why does the 3.6 seem so quiet compared to the 3.0? Is it just they were engineered to be quieter?
1980 911SC Targa 3.6L |
B58/732
I can't help you there, but at least I now know I'm not the only with a 3.0 that whines.
Fan design? Bearings? "None of the above"?
ΜΟΛΩΝ ΛΑΒΕ I don't always talk to vegetarians--but when I do, it's with a mouthful of bacon. |
I think it's the diff that whines. My '80 930 whines like crazy.
When I'm driving in parking houses, it sounds like a sowing machine. Thought maybe new tranny oil would help, but no luck.
Arnljot 1980 930 GT35R, TurboKraft IC, 965 P&C, 964 Cams, Tial WG, ported heads, BLWUR, RarlyL8 hdrs&mfflr, Zeitronix logger & wideband 1989 928GT 1972 BMW 3.0S |
B58/732
My whine definitely isn't the diff--it still whines when I'm in neutral.
Friend of Warren
My '86 Carrera makes the same noise from the fan. Really does sound just like a turbine.
Kurt V No more Porsches, but a revolving number of motorcycles. |
2 reasons for less fan noise;
1st the fan is driven at lower speed than on earlier cars, pumping ~100 l/s @6000rpm less than the older cars despite its larger diameter 2ndthe shape of the blades, as on submarines, was designed to be quiet
I'm off the hook.....
My mechs tell me that the chains are what whine. When I had the Carrera tensioner (oil fed tensioners) mod done, and the ramps, guides and chains themselves changed, they said the whine might change a little because of the differences. It did change. They were louder for a couple of days, then went back to the usual.
They did a valve adjust, and a valve timing check and discovered that the rocker shafts on one bank were incorrectly offset. They recentered them in their holders, and couldn't see any damage from that. It was obvious (scars on the head under the chain cover on the same side) that one chain had let go in an earlier life, and the guy that did the repair didn't know his way around a p-car. Sometimes, not even a pretty complete prebuy inspection catches everything. Michael Krebs '80 911SC SCWDP '83 944 |
My 3.2 whines too. Mine is fan belt and pulley related. If I over tighten my belt I can make it go away. But the belt deflection is too tight.
I believe it's because we can't get a 9.5mm wide belt. IMO. Not based on scientific measurement.
Cary 77 Carrera RS w/3.2 #59 73 914S 2.0 AG 73 914 1.7 Driver ( daily driver, under complete rustoration ) 74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor |
There was a thread about this last month. 10% of teh noise is the fan. About 90% is the chains.
The "turbine whine" is one of the things I love about my '88 Carrera 3.2. Other than that, I like wine.
Belgik 1988 Carrera 3.2L |
