Instrument panel. We looked at every option in aftermarket gauges, and finally came to the conclusion that there would be no better gauge than to stay with the original VDO's. We looked at replacing them because the originals were so cruddy. Well, one call to North Hollywood Speedometer solved all that. Harmut was such a pleasure to work with and his work is outstanding!! Just look what he turned these cruddy originals into! Yes, these are the same gauges with the exception of the speedometer. Had to have an electronic speedo to go with the G50 gearbox! We also upgraded to LED lighting, had a boost gauge installed in the tach, had the tach dampened, and reworked the clock to a quartz movement. His cosmetic restoration was perfect! Had the dials and pointers repainted and had our TAJ Motorsports logo silkscreened on the tach. Eye candy is what this is!!
Tim
A lesson learned in life...you have to figure out how to smile with a mouthful of crap.
Old 09-25-2013, 11:01 AM
Great project!
Question regarding the fender mounted oil cooler. Is the U shaped fitting that links the two coolers available or did you have that made?
1976 911/S/SC/BASTARD
Mid9 Member #12
Old 09-25-2013, 12:27 PM
kjchristopher's Avatar
Originally Posted by tchesney View Post
Made a template to brace up the lower control arm.
What weakness or forces are these braces being added to address?
Old 09-25-2013, 01:04 PM
Originally Posted by RichMink76 View Post
Great project!
That is a -12AN 180 degree fitting from BAT. They have everything weird in the AN world and Porsche cooling products. Great guy to do business with.
British American Transfer
Tim
Old 09-25-2013, 01:07 PM
My background is building and restoring vintage muscle cars, and I either replace these type cars suspension parts with beefier parts, or I simply box them or brace them to make them stiffer. This is my first Porsche, and simply looking at the lower control arms, they seemed like they could use some stiffening, so I came up with these. Besides, there was the aesthetic factor too. They looked cool!!
Tim
Old 09-25-2013, 01:14 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Tim has a good sense of stiffening. Those holey triangles were used by the factory on the rally cars!
006 | Flickr - Photo Sharing!
Kevin L
'86 Carrera "Larry"
Old 09-25-2013, 01:17 PM
I had no idea! Thanks for that tidbit of info. Is that your car in the photos? I really like your dolly. That mount up to the suspension points?
Tim
Old 09-25-2013, 01:28 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Ho ho no way that's not my car.
Just a link I saved for reference in the future when I get around to doing some chassis stiffening on my rickety '79 racecar. I figure if it was good enough for the factory SC/RS rally car, it's more than enough for my wimpy road race car.
Kevin L
'86 Carrera "Larry"
Old 09-25-2013, 01:34 PM
Mr. C
SAY - 642's Avatar
" Holy Fork-Tailed Devil, Tim "
Thanx for sharing your project. I wondered who got that 993 TT engine.
" Mr.C "
Six = Sex
Old 09-25-2013, 01:36 PM
I knew I was going to have to come up with something to fit here when I removed all the heater stuff, and was really dreading it. I looked all over for a cover for this but couldn't find one. I'm sure some of you readers probably know where to buy something like this, but our shop fabricates a lot, so we got out the old beat bag and hammer and came up with this!!
Tim
Wiring. Figured there was so much hodge-podging going on, we would just use the KISS method of wiring. Keep It Simple Stupid! Good old Hot Rod wiring harness kit will be just the trick to keep this all simple. Agree?
Tim
Old 09-25-2013, 01:42 PM
Awesome project, i want one just like it!
Old 09-25-2013, 01:55 PM
islandflyer's Avatar
sub.
Jose
87 Carrera ( Nougat Brown ), 11 Subaru Legacy (daily
driver), 08 VW Passat wagon 2.0T (wife), 03 Audi A6 2.7T (sold) ), 98 Pathfinder (sold),
02 TT 225QT coupe (sold), 03 Audi A4 Avant (wife)GONE...
Old 09-25-2013, 02:11 PM
Pedals. Decided on these pieces of art from Tilton. Oh the modifying that's going to have to be done to mount these!!
Tim
Old 09-25-2013, 02:46 PM
Remember earlier on I mentioned I was using square tubing for a reason? This is why, so I could better weld to these pieces of 12 ga. plate to the sub-frame assembly. Also, by welding these pieces in, it really stiffens up the 'cage' back there.
Tim
Old 09-25-2013, 03:13 PM
As with most every fabrication job we do here, we do it in cardboard first. Here is how we are bringing the 'tunnel' and the rear cage area together and working it into the floor pan.
Tim
Old 09-25-2013, 03:45 PM
Rip everything back apart to put it in primer and re-assemble yet one more time!
Tim
Old 09-25-2013, 03:51 PM
We've found that the more mock-up you do, the less problems you have later on. So we're mocking it all up once more.
Tim
Old 09-25-2013, 03:56 PM
Grappler
Rodsrsr's Avatar
How will you adjust the shift coupler? Awesome build!
Grappler
Know Gi / No Gi
1976 RSR Backdate (Turbo 3.2)
Old 09-25-2013, 04:08 PM
We always try to come up with something that no one else has thought of, so we decided to put the "third brake light" and turn signals in the roof vents. We think it looks awsum!!!
Tim
Old 09-25-2013, 04:16 PM
