RDM RDM is online now
Coram Deo
RDM's Avatar
Loosening light bulbs
My front passenger-side marker light / blinker stopped working last week. I figured it'd be a simple bulb replacement, but upon taking the lens off I learned otherwise.
The bulb is well fused to the reflector / pot metal piece. Is there a recommended way of removing these, or is it just use a hammer and if it breaks it needed to be replaced anyway? (yes, that was a joke).
I considered unplugging the wires on the back, but there's precious little hand space for my fat fingers once re-connection time comes.
How to get this apart? And how to prevent this in the future?
Many thanks.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 10-05-2013, 06:28 AM
Michael T's Avatar
I have used a paper towel wrapped around it tightly. Once I had the glass separate from the metal base and used needle nose pliers inserted in the inside off the base and pushed out the handles while turning counterclockwise.
1987 928 S4 - Black
2014 C4s 991 - Agate Grey
2014 Cayenne - Mahogany metallic
Old 10-05-2013, 08:20 AM
Electrical spray lubricant might help the situation.
Old 10-05-2013, 09:13 AM
Coram Deo
RDM's Avatar
Michael,
I'' give that a try. I envisioned something about removing the glass so that I could get to the base with more force.
Kevin,
I've never heard of the stuff. Do you have a recommended brand?
Is this preventative, or helpful in getting the current bulb out?
Dru
Old 10-05-2013, 10:59 AM
CRC makes a number of electrical cleaners and lubricants. Radio shack, Home Depot, or any auto store will carry some form or another of a contact lubricant. They can work well to liberate locked components.
Old 10-05-2013, 11:13 AM
i do what Michael T suggested. Twist off the glass and mangle out the metal part with needle nose. they crush up pretty easy. then clean up the socket with a little wire brush
Old 10-05-2013, 05:13 PM
