1983Cabrio
Update to 1983 Overheat no start -
HI Guys! I wanted to give you an update on the project! I FIXED IT! Turns out that yes, the heat from the engine melted the CDI. The C8 energy storage capacitor was failed open. (melted) - so I have a new Master Blaster coil as a spare, but the Black original coil is FINE! Green wire is FINE! And with an oil change (because of the heat) there were no metal fragments in the oil. A wicked catastrophe averted!!! I am SO RELIEVED!
Reiver
Good outcome, I'm surprised I haven't fried one in our Az summers.
good to hear. perhaps you should adresse the cooling issue . does your car still have the trombone oil cooler?
82 SC , 72 914 |
SMHemmah
Good outcome.
Work on the heat issues. It is worth it to be confident when the Heat is On.
1969 911T Body with 1970 911T 2.2L block with 911S 2.7L P&C and crank |
1983Cabrio
Yes, I am sure there is still some fuzz from some critter that was in there when I bought the car... I removed as much of it as I could without completely removing the shroud. With the new plugs, new timing, and new oil, it seems a bit cooler. That stand-still traffic and the heat was a unique thing... I know better now, to pull over or GO HOME next time...
CDI rebuilder......
Cabrio,
Who did the repair on your CDI? Could you share this information with us? Thanks. Tony |
Coram Deo
Tony,
Bob Ashlock on the board checked two CDI boxes for me for the cost of postage. Very thorough and professional. He would have done any repairs as well (at additional cost), but the box my mechanic said was bad was fine. I highly recommend him. Dru
Dru 1980 911SC Targa Petrol Blue Metallic Cork special leather Sport Seats Limited Slip 964 Cams SSIs Rennshifter 1990 250D Opawagen 1995 E220T Sportline Familienwagen 1971 280SE Beverly... hills that is 1971 Berlina 1750 Faggio Last edited by RDM; 11-17-2013 at 05:29 AM.. Reason: clarification of costs |
Great news, and glad it was a simple fix. Time to change fuel filter, air filter and verify you have a pop off valve on the air box.
