Removing Ignition Wires
I need to replace my ignition wires. It seems like you really have to tug on the connector to get it to release from the distributor cap. However, it's hard to get a good grip on just the connector and pull up. I'm concerned if I grab the wire and pull that I'll rip the wire from the connector. With the old wires I'm not concerned, but if I need to do maintenance in the future and have to remove the wires I obviously don't want to ruin them.
Is there some trick or tool that makes this easier? Also, is it just as hard on the other end to pull the connector off the spark plug?
1987 911 Carrera coupe - Guards Red 2010 997.2 C4S 6-Speed 2005 Mini Cooper Convertible (R52) - Wife's car 1977 VW Bay Window Camper Bus |
Senior Member
Replace the distributor cap unless it is new - that would take care of it.
Use boot "grease" on reassembly to prevent this in the future - both cap and plug ends of wires.
'78 Targa in Minerva Blue |
Distributor cap and rotor are new as of 3 months ago. My mechanic replaced them, and probably should have done the wires at the same time but didn't.
If you're like me you'll use this as an opportunity to get more tools.
I have a couple neat pliers that are called (I think) hose pliars with a circle like loop at the end, great for pulling vacuum hoses etc off without damage. would also work on dist cap wires. You can grab the boot and spin it gently to break it free. ![]() Maybe HF or Northern tool has some, I'm not sure where we got ours but most likely a benefit of my neighbor not being able to stay off the SnapOn truck :-) Chuck.H '89 TurboLookTarga, 365k miles |
Registered Loser
Slide the round end of a large paper clip in the boot you are trying to pull from the cap. It breaks the suction and the boot will come off pretty easy.
Current Rides:: 1987 Red 911 Targa, 2007 R320 CDI, 2003 Red Dodge Ram Hemi, 1993 Beater Jeep Cherokee, Airbus A320 Gone but not forgotten: 1981 VW Scirocco S, 1989 Honda Accord Coupe LXI, F-16C (still my favorite vehicle!),MC-130P, C-130E, T-38, T-37, C150, C172, PA180 |
Senior Advisor
yeah, pull the wires and the cap off at the same time, ether trash them or work on on the bench, i twist and pull. WD-40 on the cap makes them go on and come off easer. Get in the habit to pull them off every year to look for corrosion (the green stuff) that should make it ease to go back on.
08 Cayenne Turbo |
I just used a pliers to pull mine off, just twist to break the seal then pull up. Now getting NO 6 on is a bugger, I had to move the AC comp out of the way to get a good hold for proper seating.
Bob
2009 C2S cabriolet 1987 Targa - sold 2003 BMW X5 - sold |
