Question for those who've done a heater backdate
I've got an SC engine in my 72, so not really doing a backdate, just connecting the various pieces. I've just done a quick and dirty hookup to the passenger side (driver's side flapper box needs repair) and I'm wondering what, if any, air filtration people have used? I have a pretty nasty oil leak (RMS - engine's coming out this winter to repair) and I'm getting a lot of burnt oil smell inside with the heat on. Is there anything I can do in the short term to filter the air coming in? We've hopefully still got a few weeks of driving left before the car goes away for the winter (and surgery) but I definitely need the heat on!
the only to do is put tin to deflect the oïl of your heat box
Fix the oil leak :)
Give the engine a good bath and remove as much gunk as possible. You are not smelling newly leaked oil but the fumes from deposits once the block warms up.
My '74 had this problem and the way I cured it was to fix the leaks as well as keep the engine spotless.
For cleaning, I spray cleaner in thru the fan, with the engine off, and let it soak in. Then with the engine running, I spray the hose right into the fan and it forces water onto the engine fins. This does a pretty good job of cleaning the engine and I've been told that this is a method used on the race track. I recently removed my CIS and did oil leak maintenance. I was surprised to see oil was leaking right out of the low-oil-pressure switch that is on the top/back of the engine. My next cleaning project is going to be getting some wire type cleaners (like pipe cleaners) and scrubbing between the fins from below. I suspect that there is ground in and stuck grime. |
What type of a cleaner are you spraying through the fan? Would something like Simple Green work?
Now that I've gotten my engine clean after several cleaning sessions, I am able to keep it clean with light soap and water. I really think the strong hose stream thru the fan (while the car is running) has helped keep the engine clean - I do it almost every car wash. |
| All times are GMT -8. The time now is 06:38 AM. |
