I'm going to dip my next project - an '86 911 - to compare metal stripping techniques. I'll start that build thread soon. |
nice chris...can you share more about what the "ceramic" product was that you used...the +/- of using is...how it is applied...? also, is the tilt dolly a totally different dolly set up than the latest pics of the car right side up on its' dolly...??
I am wondering what is the best dolly set up to use to replace the entire bottom side of a 911 tub to have the tub be moveable, access to remove & install the new panels & be the best to support a tub w/o its entire floor in place while it is being replaced so not to wind up with a twisted & curvey potato chip when all done...
I live for 911 tweaks... |
AutoBahned
I thought by ceramic coating, you were talking about a product similar to products used on heat exchangers, pistons, etc.
But now it looks the ceramic undercoating is really one of the undercoating sound barrier products that contains ceramic micro-beads embedded in a matrix of elastomer. Correct? If so, i never thought of using it on the outside of a tub - I guess it is like using some of the Wurth flare protector type products (?) BTW - IIRC, there is a major unit body sized dipping facility in the SE. Thanks for posting about a very interesting build up. |
Any updates?
Almost 1 year anniversary anything new?
Sorry or the long delay in replies and updates. What started out as a passion project has turned into a nearly full-time business. Therefore, updates are second in priority in the moment.
What seemed like an eternity in the metalwork phase then turned into another eternity in the bodywork phase. Finding a competent shop in my area was tough, but we stumbled upon an incredibly talented and skilled shop to help execute our vision. Here is the body in rough metal as we dropped it off: ![]() Note the reshaped flare profiles. A polyester sealer went on and then it was time to use a little filler and rod to perfect the gaps: ![]() ![]() Ready for the final sealer coat: ![]() ![]() The rendering of the final product:
Beautiful! The side-script is classy - how is it applied? Is it a custom thing?
Awesome. Two more:
Which color? Is that the fabled "slate gray"? And how did you generate that wonderful render? |
Whow! what a beauty!
Banned
looks great!
I was just in Nashville and missed this :-(
I love the stripe! |
It is indeed shiefergrau. Glasurit's color information system still maintains the proper '63/64 year mix for the original 901/911 color and that's what we used. It appears the mix changed a little bit in later years.
PM me if you want a hand installing the head liner. I'll be in town again next month.
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html |
Wow, love it.
| Tags |
| long hood , restomod , restoration |
