-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   Sorry - Yet another CIS troubleshooting thread... (http://forums.pelicanparts.com/showthread.php?t=780952)
fanaudical 11-10-2013 08:24 PM
Thanks in advance for the help. I thought I was relatively adept with CIS troubleshooting (lots of previous experience on old Audi stuff, but apparently not serving me well on this one). I'm hoping the CIS gurus here and point me in the right direction.
Our patient is a '75 Targa with a newly rebuilt (by me) 2.7L in stock trim; stock CIS P&C's, stock cams, freshly-redone heads, and stock CIS. Part numbers for the major CIS components are:
WUR: 0 438 140 009 (with vacuum port)
Air flow sensor: 0 438 120 004
Fuel distributor: 0 438 100 006
There is no idle air control valve or enrichment valve on the throttle body. The bypass air valve is still present, connected, and pops open ~550 mm Hg of vacuum. I flushed the tank/lines/fuel pump during the rebuild and installed a fresh fuel filter. Injectors are "reconditioned" by a professional injector service and tested for drips and spray pattern (more on this later). The EGR valve is present but "isolated" so that it will not open.
Initial symptoms: The thing was "jerky" at light-load/part-throttle conditions from ~2200-3000 rpm. It also "popped" out the exhaust when lifted completely off the throttle at >2800 rpm. This started as a minor problem ~50 miles after initial start-up and progressively got worse over the last several weeks.
Since most CIS problems are really ignition, I started there. I already had fresh wires, plugs, distributor cap, etc from the rebuild. Vacuum retard and mechanical advance working correctly. Pertronix installed and working correctly. I verified no cracks in the distributor cap.
I did determine that the distributor had excessive axial play (wasn't that way at start-up) and pulled the distributor. I pulled the distributor apart and shimmed the main shaft to remove the end play. I measured shaft run-out once reinstalled in the distributor and found no radial play at the rotor.
Fixing the distributor end play removed the exhaust popping and improved the jerking, but did not eliminate it.
Initial idle mixture was set with the "lift the air plate" method; it will idle smooth, and timing is set at 5 ATDC (stock). Oregon DEQ tells me that idle mixture is at 2.3% CO. I did richen it a tad without luck.
I rounded up the following diagram for the WUR:
http://forums.pelicanparts.com/uploa...1384142218.jpg
Here are my test pressures with my CIS test gear:
System pressure: 4.8 bar
Cold control pressure (15°C): 1.4 bar w/o vacuum
Cold control pressure (15°C): 1.8 bar w/ 400 mm Hg vacuum
Warm control pressure: 3.1 bar w/o vacuum
Warm control pressure: 3.5 bar w/ 400 mm Hg vacuum
Leakdown: dropping below 1 bar in 10 minutes
Near as I can, everything is where is should be (except the leakdown). I have not yet pulled injectors to personally check for leakdown and spray pattern. I have not verified fuel pump delivery volume yet. Interestingly enough, there are no hot starting problems (the normal reason for needing good pressure retention on leakdown). I'm guessing that my leakdown issue is across the WUR.
I pressurized the air box (vacuum cleaner in reverse with air box on the car) to check for excessive leaks. I find one "slow" leak on one seam; am guessing there may be others.
After much research, I ran across another CIS thread where it was advised to temporarily disconnect/plug the vac line to the WUR; I tried that and the majority of the jerking at light load disappeared.
Three questions:
#1 - WHY does disconnecting the vac line to the WUR mostly solve this problem?
(My best theory is that there is a vac leak in the air box and disconnecting the vac line to the WUR enrichens the mixture across the lower operating range to counter this.)
#2 - What else (not mentioned above) should I be doing to troubleshoot this?
#3 - What else do you want to know?
Thanks for the help.
timmy2 11-10-2013 10:31 PM
I believe you are on track for the vacuum hose removal enrichening to compensate for false air.
Think about how small a volume of air the vacuum method is pushing and then reverse that flow with an engine running, trying to get as much air as possible.
A small pressure leak is a huge vacuum leak.
Replace the airbox....
prebordao 11-11-2013 06:22 AM
It seems your system pressure is at the low end of the admissible range.
I would try to get it to 5.0 and do a run.
I also had some jerkiness at partload (2-3K) and increasing sys press from 4.8 to 5.0 (and thoroughly cleaning the return line path) seemed to fix it.
However, a vacuum leak may also cause those symptoms...
fanaudical 11-11-2013 06:48 AM
timmy2 - Thanks for the reality check on what a leak means. I'll definitely pull the air box and investigate further.
PJR - For reference, I found the info for this WUR in this post:
http://forums.pelicanparts.com/3543078-post7.html
I believe Mr. Sims pulled this info from his Porsche spec book, and this would indicate that 4.8 bar is right in the middle of the range. However, I can see how increasing the system pressure might rebalance things. I'll give that a try if the air box fixes don't improve things.
prebordao 11-11-2013 06:54 AM
Yes, you're right. Minimum is 4.5, but you can try it as it's very simple...
Paulporsche 11-11-2013 06:59 AM
I don't think I saw a mixture reading (CO%). A too rich mixture can cause the symptoms you mentioned.
Keep in mind that sometimes people richen the mixture to make up for vacuum leaks.
Check the fuel lines. If they have been replaced by ones that have too thin a wall, you can get surging @ low speeds.
And raise the fuel pressure as others have said. 5.0 seems sufficient.
timmy2 11-11-2013 08:41 AM
Fanaudical,
Do you want to borrow my Gunson CO meter?
I'm down the road a bit from you in West Salem.
PM me and we can figure something out. :)
theiceman 11-11-2013 01:07 PM
^ start here ..
Newfie911s 11-11-2013 01:27 PM
When I was having issues it was with the WUR which was totally screwed. I followed the recommendations from the members here and its all working.
My system pressure was up around 7 bar if I remember correctly. See below this is the thread that finally got me running well.
1977 911s Fuel Pressures
fanaudical 11-11-2013 08:27 PM
I had CO measured at ~2.3% during a recent emissions check (but did increase mixture to ~2.5%, which did seem to make the thing run better).
It sounds like the most prudent thing to do is to remove the air box and make sure all the leaks can be sealed (or replace the air box if not). I will do that in conjunction with bumping up the system pressure. When I get to that point, I will give timmy2 a PM and make sure I've got the CO meter available (thanks for the offer!).
timmy2 11-11-2013 08:48 PM
No problem, happy to lend a hand or tool when needed.
fanaudical 11-12-2013 07:07 AM
Paul - Sorry, missed your post. Can you please explain to me how a too-rich idle mixture might cause the problems mentioned? I wasn't aware that position of the idle adjustment screw affected how much fuel was metered when the air flow plate is raised off rest past an idle condition.
I have replaced almost all my plastic fuel lines, but did use the "good stuff" - Cohline fuel line for CIS that I purchased through BoxsterGT here on the forums. I did investigate this one, and have not run across anyone with surging issues traceable to this specific fuel line type.
boyt911sc 11-12-2013 07:44 AM
CIS troubleshooting.......
fanaudical,
I've been following your post since the very beginning and you are doing good. So I just stayed back and watch this developed. You need to do a pressure/vac test to determine if your engine is getting unmetered air. Without testing and verifying the integrity of your vacuum system, you are guessing and hoping that there was none (air leak). It maybe that's the case, but without testing your air box and other areas affected by unmetered air diagnosing your problem would be tricky (difficult).
BTW, do you have a pop-off valve? Keep us posted.
Tony
T77911S 11-12-2013 07:58 AM
very good job. nice to have someone that is clear with their results and to the point and thorough with their testing.
first thing i noticed is even though your WUR may be in spec, it is only getting a .4bar change in pressure with and w/out vac. personally, i would like to see about .8bar. with 2.8bar with no vac and 3.6 with vac.
have a smoke test done. it may be worth while to test your air box properly, or just get another one.
what is the timing at full advance? set it for full advance, not idle.
i dont know if i should say this or not.. timing can cause the popping off throttle. with not enough advance and the retard connected, it can pop.
personally i like the retard at idle. it sounds better and it is out so fast its like another advance, also, i think you can run a little richer mixture because of the retard at idle.
is the WUR connected to the correct vac port on the TB? this should be manifold vacuum. if you look at the ports and look inside the TB, you can figure out which ones are above the plate and which on es are below.
did you replace the boots on the intake runners? are they secure? what about inectotrs sleeves and Orings?
how about injectors? do a flow test and compare the volume of the injectors. put all 6 in containers, turn the key on and lift the plate. the more fuel the better the test. this also check the FD and lines.
fanaudical 11-12-2013 09:26 PM
Thanks for the kind words. Here are some answers to the questions:
Yes, I do have a pop-off valve installed. (Wish I had found Peter Z's treatise on the evils of the pop-off valve before doing it.)
I have done the "reverse-flow vacuum cleaner pressure test". Injector sleeves, o-rings, and runner boots are new. Injector sleeves and seals are tight (no bubbles). Runner boots are tight. Pop-off valve is tight. I did detect a minor (one bubble per 10 seconds) on one accessible seam of the air box. I'm guessing that there are more leaks in the seams I can't reach. However, it does seem to me that the system should be able to compensate for small leaks like that.
Interesting note regarding the WUR pressure change with vac/no-vac; I didn't catch that the difference was only about 1/2 of what is indicated by spec. (I applied vac with my hand-held vac pump for the test, so should be fairly accurate.) I'll have to investigate that.
The WUR is connected to manifold vacuum, but the vac line to the WUR is also tied into the decel valve. An open decel valve will limit vacuum available to the WUR when it opens.
New question: Is there any possibility my decel valve is opening too late? How much vacuum should be applied to the decel valve to get it to open?
To be honest, I have not yet set timing at full advance. I don't have a lot of time on this engine yet and am somewhat timid about running it up to 6000 rpm and holding it there with no load. (I guess I'll just have to get over that.) I have checked timing at lower RPM's and it seems to follow the published ignition advance curve to 3000 RPM.
Seems my next course of action (in order) should be:
[ ] Verify timing at full advance
[ ] Retest the pressure change from the WUR with vac/no-vac. Check that there isn't a malfunction in the the WUR.
[ ] Injector flow and spray pattern test
[ ] Pull the air box and properly test all seams for leaks
Any and all comments appreciated; thanks for the help.
T77911S 11-13-2013 05:46 AM
you dont have to hold it and you dont have to go to 6k. rev the engine and you will see the advance stop coming in. rev it and check it. set it at idle, then rev and check. you will be OK.
dont sweat the decel (DV). it should be closed at idle, when vac is highest, then when you let off the gas, the higher vac will open it. i am sure there is a spec but you can use your handvac and check the idle vac. then pump it up to see when it opens. should be just a little higher than idle vac. thats all i did with mine. just made sure it was closed and it would open but most important,it did not leak.
i ended up removing my DV when i put a 3.0 throttle body on my 2.7. i think its a noce little mod, not much mentioned on here about it. kinda suprised.
fanaudical 11-17-2013 06:14 PM
I haven't had a lot of time to play with this. (Been wrenching on the wife's daily driver all weekend; I'm never buying another car that needs timing belt service where the first step is to remove the front of the car ever again.)
I did check timing at full advance (got the car warm, disconnected/plugged vacuum module, quickly revved it, watched "peak" advance) and it looks like I'm getting 30° BTDC. I also tried with vacuum module connected and also see a maximum of 30° BTDC.
Went to check Wayne's book; it indicates 38° BTDC (I'm assuming maximum) with hose connected. My other manual references 32-38° BTDC with hose disconnected. Here's a advance curve I pulled from another thread (this appears applicable to a 2.7L in stock config with CIS):
http://forums.pelicanparts.com/uploa...1384740729.jpg
Anybody have definitive timing advice that works well for a stock 2.7L? Looks like I can advance timing another 2-4° safely and reset idle/mixture and see how it works.
Millweigh 11-18-2013 05:54 AM
One Possibility
Fan, I have followed this thread closely as it caught my eye due to a similar
problem I had. I could not push past 3200 RPM in any gear, under load and with
the help of many of the forum members that have supported you, they coached me to
a solution. I can see where you have verified your motor to "Spec" and for
most DIY'ers, beyond. I have one thought that you may want to consider and it
is based on the KISS principal: The Bosch CIS fuel distribution works with
differential fuel pressures, the system pressure and the regulated pressure
provided by the WUR meet in the fuel distributor (FD) to ensure accurate fuel
flow. In my 77 911S, the WUR did not provide enough pressure to balance the
system pressure in the FD and thus, a restricted or limited fuel flow. It flowed fuel
with a manual movement of the control arm, but the movement needed with air
flow was restricted due to a low differential pressure. With all the
testing and replacements you have done, have you gone inside the FD to verify
there is no obstruction or blockage in the metering system? I know it is a
challenge and something I would not want to do, but from my vantage point, I
would take a look in that direction to verify proper flow. I do not recall seeing a
lot of "How To" information on verifying the FD, but from my limited experience
and seeing all you have done with pressures, timing and electrical system components,
the only thing left to verify is FD performance. I am sure the
"Experts" on this forum will have more comments or thoughts, but the FD is what
I would consider/pursue.
Charles Freeborn 11-18-2013 11:30 AM
All good points made here. If in fact the FD is your culprit I'd recommend giving these guys a shout:
CISFLOWTECH
There are very few qualified repair people for the Bosch units. They're not particularly complex - either in concept or construction, just precise and finicky. I'm a die-hard DIY'er, but sometimes you gotta know when to hold 'em and when to fold 'em.
They will also e-mail you a very thorough manual with all the pressure testing data you need, or if you PM me I can send you what I received from them.
-C
kodioneill 11-18-2013 12:40 PM
I've seen this same issue before and it was the pertronix ignition unit. Did you substitute points just to eliminate the possibility ? Did you use a scope to check ignition under load? As you said ignition is the problem most of the time. It only takes a minute to test a set of points.
fanaudical 11-19-2013 08:09 PM
As usual, you guys have lots of good info to consider.
I did casually check total movement of the fuel distributor during my rebuild; I didn't detect any issues there. I'll check again.
I have not put a scope to my Pertronix yet, but that is a very good suggestion. It may be better to swap the points back in and eliminate that.
One more bit of possibly-related info - I'm also not running a stock coil (I have a Pertronix 45111 coil instead). This came up in another thread:
http://forums.pelicanparts.com/porsche-911-technical-forum/782721-pertronix-flame-thrower-coil-compatible-cdi.html
More info back when I get some testing done...
fanaudical 12-14-2013 04:10 PM
Still haven't had a lot of time to play with this. I did test my decel valve and found that it was cracking open at much lower vacuum than where I thought I had set it (it was opening ~15 in.Hg which would have had it open at open and some part-throttle conditions).
I reset the decel valve to open at 22 in.Hg (car was idling at ~20 in.Hg at previous test). Drivability is much improved, but I still need to go through the other items mentioned above.
boyt911sc 12-14-2013 06:18 PM
Decel valve operating pressure.........
Fan,
The operation of the decel valve (opening/closing) has no effect to the vacuum supply to both decel valve and WUR. Unless the diaphragm inside the DV is ruptured or broken. The release of excess vacuum during deceleration of the engine is channeled to the lower chamber of the DV. A valve is activated to open at a certain vacuum setting (?). So the question is at what value? I searched for this value and came short. But when I tested six (6) decel valves for opening pressure, I found that around 22"+ Hg, the valve pops open. So I've been using this value for setting the decel valve.
Tony
fanaudical 12-14-2013 09:16 PM
Thanks, Tony, for testing a few decel valves. It looks like I guessed correctly.
Here's a picture of how the vac lines are routed at the decel valve:
http://forums.pelicanparts.com/uploa...1387084161.jpg
The larger-diameter vacuum line that "leaves" the picture to the right is the line going to the WUR as vacuum reference. Let me try to explain my previous statement a bit better.
I recognize that the decel valve gets opened by a separate vac line than what operates the WUR. However, when the decel valve is opened, the WUR no longer references manifold vacuum directly; the pressure reference for the WUR will increase (decreased vacuum) because of the air spilled into the line by the decel valve. Therefore, when the decel valve opens up, two things are really happening: Air is bypassed around the throttle plate and the WUR slightly enrichens the mixture.
boyt911sc 12-15-2013 01:53 PM
Wrong connection.....
That is not the right connection for the vacuum line!!!!!! The tee-connection is hooked up on the top of the decel valve not below as shown in your picture and goes to thermo valve. Then thermo valve to WUR. Your logic is correct about the vacuum lost during operation based on your current set up. But the fact is that you have the wrong set-up.
I'm not home today and could post the vacuum diagram later.
Tony
fanaudical 12-16-2013 10:51 PM
Tony - Thanks for the info. Please post that vac diagram when you get a chance.
I've got a '75. No thermovalve, and one vac reference for the WUR (located on top - no atmospheric reference ported to the throttle). I didn't think the thermovalve came into play until ~'77. This is how I found the vac plumbing done when I disassembled the engine and is also corroborated by some research.
Here's an excerpt from the early CIS microfiche that I found online somewhere; it references that the WUR I have only gets a post-throttle-valve vac connection:
http://forums.pelicanparts.com/uploa...1387263047.jpg
fanaudical 06-29-2014 04:56 PM
Well, I took a "hiatus" from this problem to strip the car apart over the winter and make it pretty (replacing front fenders to eliminate the rust holes, fixing a bunch of body stuff, full wrap to get it all one color, etc). I finally got it back on the road briefly last weekend and again today for a longer drive. Oddly enough, the problems aren't as bad as I remembered. (Doesn't mean they're not there...) Back to troubleshooting.
One question: How much does indicated oil temperature (engine temp) affect operation of the CIS? I think my on-engine oil thermostat may be stuck open - engine is not getting above 180F. (I have verified oil temp with independent temp probe right in the oil tank.)
ossiblue 06-29-2014 05:15 PM
The engine temp should not affect the wur as the wur is heated via the electrical element on the bimetallic arm. You should be able to see pressure changes simply by running the fuel pump and applying power to the heating element.
fanaudical 06-29-2014 05:31 PM
Thanks, L.J. As soon as I read your response I smacked myself on the forehead with a "I knew that" moment. I've been doing too much bodywork. I made myself go back and re-read the whole thread and dig through my Bosch CIS book.
Resetting my punchlist:
[ ] Verify timing at advance is 32-38° BTDC (was 30° last time I checked, will probably bump to 34°)
boyt911sc 06-29-2014 07:12 PM
Nope.........
Larry,
My friend, I have to disagree with your statement!!!!! The control fuel pressure is directly affected by the ambient temperature (meaning surrounding temperature). This includes the heat generated by a warm engine in the engine bay. As an example is the chart of the of the control fuel pressure for -009 attached in the previous post. As you could see from the chart, the value of the control fuel pressure is linear to temperature change.
Tony
mysocal911 06-29-2014 08:17 PM
Originally Posted by boyt911sc (Post 8140632)
Larry,
Tony
That's correct, i.e. both affect how the CP changes as the engine warms up, but the
heater element reduces the warm-up phase and allows the CP to reach it final value
which may not occur without the heater functioning properly.
fanaudical 07-18-2014 09:52 AM
OK - Finally got to play with the car again.
I verified timing is at 34° BTDC at full advance.
I retested my system pressures:
Cold control pressure (20°C): 1.6 bar w/o vacuum
Cold control pressure (20°C): 2.1 bar w/ 400 mm Hg vacuum (2.2 bar @ ~200 mm Hg?)
Warm control pressure: 2.85 bar w/o vacuum
Warm control pressure: 3.4 bar w/ 400 mm Hg vacuum (3.6 bar @ ~200 mm Hg?)
It does seem that the difference in no vac/vac pressures are within spec (though at the low end).
Comparing against my previous values in the original post, it seems that cold control pressure has gone up with the ambient temp increase, but warm control pressure has gone down. Also, I'm noticing that the control pressures with vacuum applied are spiking ~200 mm Hg vacuum applied to the WUR rather than at 400 mm Hg. This doesn't seem right. Do I have a failing WUR? Is it time for rebuild?
I still need to do a spray test.
Coming back to the engine operating question: I took the car for a long drive (90 minutes) after fiddling this morning. I blocked off air access to my fender cooler and the oil temp got just over 180F while driving in ~80F weather. I verified operation of the sender and gauge this past winter (hot water bath, ohmmeter, variable resistor, independent thermometer, etc) and so know that the indicated temp is fairly accurate. Could this low operating temp be contributing to the bucking behavior? My assumption is that the WUR is hitting "max temp adjust" at ~100F / 40C.
thomastee 08-10-2014 10:33 AM
As someone with the same problem of mid range bucking on a 74, I'd be fascinated if it turns out that the low operating temp contributes to the bucking. Like you, I've chased this problem for a while (ignition, pressures, air leaks etc) with no luck yet but I too have low operating temp perhaps due to a non-standard front oil cooler that a previous owner installed.
Did you crack this one yet?
Best,
Thomas
fanaudical 11-02-2014 04:04 PM
Coming back to this one:
The bucking problem essentially went away with high temperatures here in the PDX area. I pulled my CIS off last weekend and while it's out I'm going to change both the engine and external thermostats to be sure I'm at proper operating temperature.
Unfortunately, my whole CIS unit fell off the workbench and destroyed the airbox. I'm currently sourcing a new one. The next step is to replace that one and then start retuning.
fanaudical 01-03-2015 01:08 PM
Update (and "close-out" report):
I located a replacement airbox and discovered that it also had a few minor leaks. In searching for what to use to seal this, I considered these ideas:
- Using epoxy to seal the box as several here have done
- Welding the airbox
- Sealing from the inside with something like gas tank sealant
- Designing/building my own
I investigated the weldability of the airbox and determined that the plastic this thing is made from is not a great thermoplastic. Best I can determine, the airbox is made from carbon-filled polyphenylene sulfide (PPS). I experimented with a few different epoxies and determined that flexible epoxies containing methyl methacrylate bonded very well to the airbox material. (I eventually used Loctite "Plastic Welder" which is readily available.) I used a Dremel tool to route out a partial groove around the periphery of the seam and filled it with this epoxy.
I haven't given up on the "sealing from the inside" method yet and am considering this my "backup". I see some challenges in cleaning the inside of the airbox. My thought is to use something like POR15 gas-tank sealant or an aviation gas tank sealant product.
Having a broken airbox to play with was enlightening. I found the plastic to be very fragile and brittle. It's only a matter of time until I have the same issue with this newer box. I'm definitely looking at designing a sheet-metal version. If anybody has interesting ideas of specific features to include in design for such a box, please pass them along. (I'm already thinking integrated pop-off valve and making it separable while on the engine to facilitate installation.)
All that said, I verified no further air leaks and then reassembled and installed the CIS again.
During the airbox fiasco, I had contacted Tony (boyt911sc) and sent him my WUR for evaluation. He found it to be out-of-spec. I commissioned Tony to do a rebuild of the WUR and received it back last week. The WUR came out of its box completely spotless and looked brand new. I tested control pressures once installed and everything was perfectly in spec. The car fired right up! I did have to adjust the idle mixture to compensate for the non-leaking airbox.
All my hesitation/stutter problems are now gone. Drivability is vastly improved.
While the CIS was out I did change out the engine thermostat; I still have to change out the external thermostat. I have confirmed that the external stat appears stuck open and the car is running a bit cold. However, since the performance of the CIS is so much improved, I'm concluding that the main culprits were a combination of airbox leaks and out-of-spec WUR.
Thanks again to Tony for helping me troubleshoot this and providing a great WUR rebuild service!
timmy2 01-03-2015 02:14 PM
The stainless Webb design air box comes up for sale once in a while.
I have one for a large intake runner car ('78/'79) you could borrow to copy if you wanted to. (not using it with my Bitz kit) :)
PM me with contact info if interested. :)
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/423504-webbs-machine-design-cis-stainless-steel-air-box.html
Info on the fitting of it:
http://forums.pelicanparts.com/porsche-911-technical-forum/660859-webb-airbox-fit.html
Good photos of it starting on post 45
http://forums.pelicanparts.com/porsche-911-technical-forum/621680-finally-back-game-3.html
Maybe this one is still available?
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/734358-webb-stainless-air-box-911sc.html
rpc356 01-03-2015 03:42 PM
Could you expand on this, or do you have a photo? I've got a spare airbox with a split seam and would like to give it a go at repairing it before just giving up.
fanaudical 01-03-2015 05:32 PM
Dennis - YES - I would very much like to borrow that box (mostly to learn from the issues I've read about with those).
Richard - I used a small v-bit and just traced the seam best I could (1/2 of the vee on each side). On the "flat" sides, I cut a groove ~0.060 deep so there was a channel for the epoxy to lay in and seal. On the side directly under the air cleaner I used a ball bit to route the groove on the lower side of the box only. Let me know if this doesn't make sense and I'll add a sketch or something.
I did find that the Loctite Plastic Welder didn't flow like other epoxies I had used (it's fairly thick) and so I had to squish it into the groove to fill.
timmy2 01-03-2015 06:26 PM
Ok, shoot me a PM.
rpc356 01-04-2015 05:51 AM
Thanks, I get the general idea. Basically, give the epoxy a purchase on flat surfaces. Once I open up the box I think it'll be clear.
