1971 911 t
I’m installing a new front harness. I’m having trouble which i believe is all coming from my dash headlight switch wiring. Does anyone have a diagram for that switch for a 71 or a detailed photo ?
What’s happening is this. My dash lights come on with the key but when you pull the light switch the dash lights go out. Then parking lights do not come on until light switch is pulled to “headlights on” location. High beams are turned on when the blinker is turned on. Any help would be greatly appreciated Andy Text 215-514-5812 Email: zurg98@verizon.net |
PCA Member since 1988
Andy, people have posted the wiring diagrams in the Forum, so do a search trying several key words. Also try your favorite search engine on the internet as they are posted in other forums too. It does sound like you got some wires misconnected.
Second, make damn sure you have good grounds.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Driver, not Mechanic
Off topic but I wouldn't put my email and phone number in my signature if I were you (unless these are for business). Bots will scan these and add them to spamming/scamming lists.
'71 Diagram.
![]() ![]() '73 Switch.
Ed 1973.5 T |
Thank you very much
