Windshield washer problem
My windshiled washer only works on the passenger side. I have checked to see if the nozzle holes are clear and they look fine. Any suggestions?
Thanks |
Have you checked the hoses running to the jets? I had one that wasn't spraying because the hose was disconnected. The washer fluid was just spraying in the front boot.
The windshield washer system uses check valves that are in-line with the hoses. They're located right under the nozzles. Have you checked to make sure they're working? Mine were plugged and I had to replace them.Take them out and try to blow some air through them.
Good luck |
| All times are GMT -8. The time now is 06:54 PM. |
