Porsche Crest Carrera 3.0 sc oil tank bubbling noise
Hi all I've got a 1975 3.0 sc carrera.
The problem I've got with it is when it's running on idle you can here a bubbling noise coming from the oil tank, had a look in the tank with a camera and you can see air bubbles coming through the oil, has anyone got any ideas?. Thank for help.
Old 03-11-2015, 08:45 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
I think it's normal. Mine ('74 with front oil coolers) does it too. I believe it's simply the dry sump being dry and the scavenging circuit getting air into itself. No reason to be concerned.
Sent from my iPhone
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 03-11-2015, 09:36 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Do you have a front oil cooler?
If the brass oil lines get pinched/crushed, it cause turbulence in the line and then makes the gurgling sound more apparent on the passenger side. This could also cause gurgling in the sump.
'85 Carrera Targa
PCA/POC
Old 03-11-2015, 09:47 AM
Thanks it does have a cooler at the front will check the lines for damage. Also if the sum is dry and the scavanger pump is sucking air can that damage the pump?
Old 03-11-2015, 03:32 PM
BURN-BROS's Avatar
No, it will not damage the pump.
Old 03-11-2015, 05:59 PM
