Electrical Connector
Does anyone know the part no. or where to get one for the 'H' shaped connector for fog light wiring. I've tried to upload a photo but don't seem able to do it.
THANKS |
The part # is 999-652-142-40
"Push On Connector" You can find it in the PET program under '87-'89 911 Main Group 9 (Electrical) Illustration 902-52 It appears as item 14. When you call to order it also looks like you will need to specify how many positions/connections. They call out 1,2,3,5,&12 I have only ever seen the H shaped (2)? They are basically an insulator that the female spade connector can also lock into. With a small thin screwdriver or the proper release tool you can bend the retaining tab flat and remove the electrical connector. Cooper |
These ones? Just need to cut 2 off and you get the H style.
Same as VW style $1 each at wolfsburgwestdotcom part #111937077 PSH WIRE CON 1-1 Just use 2 female spades instead of one male and one female. When I was looking for these in the original configuration they came up as NLA... http://img.tapatalk.com/d/14/04/26/edeqyqa3.jpg Sent from my iPhone using Tapatalk |
Thank guys for the information.
| All times are GMT -8. The time now is 09:22 PM. |
