Car driven 500 miles in 7 years. Concerns?
What should I be concerned about with a mid 80's Porsche that has driven under 500 miles in 7 years? The last stated mileage on record is from 2007. Thank you in advance.
Old 06-28-2014, 03:23 PM
Justin@Athens's Avatar
Send a message via AIM to Justin@Athens
Tampered odometer?
varnish in the fuel system
dried seals all the way around
tires no longer DOT road legal, and hardened
moisture in the engine oil
mice and rodent occupation likely
dead battery
brakes could be frozen, but the fluid is definitely shot, hygroscopic properties.
the list goes on
I assume you have taken possession of the 930?
1990 964 C4 Coupe & 1991 964 C2 Coupe (current)
1989 911 Targa (sold)
1996 993 Cab. (sold)
1999 x2 Boxster (sold)
2006 Cayman S (my daily)
Old 06-28-2014, 03:28 PM
Thank you for your thoughts. No I haven't. Just doing some due diligence while away.
Old 06-28-2014, 03:55 PM
It's definitely worth acquiring, even if it seems like a money pit at first.
Seals in the turbo can go bad as well, but its probably lower down on the list of things to look after before running.
Old 06-28-2014, 04:03 PM
Originally Posted by Justin@Athens View Post
Tampered odometer?
dead battery
the list goes on
Yes, yes, yes, yes, yes, yes...and yes. Just about covered it. This short list makes it look ohh sooo easy...but it's time. And more time.
Old 06-28-2014, 09:06 PM
