Fuel Pump Relay
On a 1984 Carrera, how long should the fuel pump run after turning ignition switch to on and the fuel system is pressurized without starting the engine? Or does the pump keep running until the ignition switch is turned off?
Old 12-20-2015, 04:22 PM
