-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   L@@K! Another AC question?? (http://forums.pelicanparts.com/showthread.php?t=820242)
Bob Kontak 07-14-2014 01:33 PM
Originally Posted by keithbkeller (Post 8163430)
I get it now. I have it right! Well, I got confused from reading some of the other posts. All trying to be helpful. So here's the deal. I have the "D" side of the compressor going up into the rear condenser and the "S" side coming from the front of the car down the long hose. And indeed the "S" side of the compressor is cold from the refrigerant being sucked into the compressor! So now I will fit it with 2 more clamps and test it with the rear hood down!
Excellent.
This winter you can do the nasty and take the hoses off and have them properly crimped at an industrial hose supply place. It's cheap. As long as you are the grunt that takes the hoses to them.
I believe the worm clamps will work as long as your pressures don't go off the scale because of an obstruction, but your lines probably aren't even flared on the ends to prevent slip off, let alone pressure loss. View as temporary.
FWIW, I have tried to repair a transmission cooling line on a domestic pickup - the pressure side lines - with rubber (transmission) hose and clamps. Not wise.
kuehl 07-15-2014 07:52 AM
Rotate your compressor 90 degrees to the right.
Like This
Bob Kontak 07-15-2014 08:27 AM
Is this what you mean? Or just lay it over to the right to get the hoses tucked back in there?
http://forums.pelicanparts.com/uploa...1405438027.jpg
kuehl 07-15-2014 08:35 AM
No Bob.
What you got there is a "lefty".
Remember, lefty loosee, righty tightee
wwest 07-15-2014 09:10 AM
Looking at the clutch face, rotate the compressor 90 degrees CW.
wwest 07-15-2014 09:11 AM
https://www.facebook.com/photo.php?fbid=10203540508224773&set=p.10203540508 224773&type=1&theater
stevedollar 07-15-2014 06:41 PM
the compressor may need to be rotated to make hoses fit properly
I installed the Sanden compressor on my 87 Carrera last year and I realized I had to rotate the compressor on the bracket 90 degrees (on its axis) so the hoses were on the right/passenger side (3 o'clock, looking forward into the engine compartment). I will try to upload a photo or two, showing the configuration.
As others have said, the engine lid has to be closed for it to work properly. Check the motor for the condenser up front, mine was fried and I had to order a new motor from PP. With the a/c charged, the fan only runs when I am stopped at a stop light. Good luck!
http://forums.pelicanparts.com/uploa...1405474717.jpg
http://forums.pelicanparts.com/uploa...1405474739.jpg
