Amazing $3.99 Chain Tensioner Install Tool
I rebuilt my mechanical chain tensioners and they are rock hard. The problem was installing the tensioners in the chain box. No combination of clamps or other devices seemed to work. And I know there is a tool for this, but I did not have it and wanted to move forward.
So, I went to the local hardware store and bought this spring claim for $3.99. ![]() I then took the rubber protectors off and set the tensioner in the clamp like this. ![]() Then, the clamp and the tensioner went into the vise like this. ![]() Cranked vise until tensioner compressed like this. ![]() Took the compressed tensioner and clamp to engine and positioned in place. ![]() Slid it in -- the clamp is so thin it slid right under the idler arm. ![]() Held the tensioner in place and pulled the clamp out. Snap! into place. Whole operation took about 90 seconds per side.
Brad Inventor of SNAPGAP - The Valve Adjustment Solution Patented in U.S. and Europe. Go to SNAPGAP.US or PM me. https://www.pelicanparts.com/More_Info/SNPVAK11146.htm?pn=SNP-VAK11146 |
Science is NOT optional
Nicely executed post.
PCA member since 1993 |
I would drill a hole in one handle of the clamp and attach a piece of string so I could yank it out from across the garage. . .
'66 911 #304065 Irischgruen 96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Thanks rbogh.
To 304065, I say "huh?" I did think about dimpling the clamp ends with a punch to create little divots to keep the tensioner from slipping out, but it did not turn out to be necessary.
So the clamp kept the tensioner compressed once out of the vise?
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
Yes. The clamp exerts a lot of pressure that the tensioner was not able to overcome. Yet, it required the vise to compress the tensioner in the first instance. So, it turned out that the clamp had exactly the proper amount of force to keep compression while also allowing the tensioner to be slipped into place in the chain housing.
I love it!
Thanks for posting that.
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html |
Coram Deo
Question: Do these tensioners not have the place to put a pin in and hold them compressed? My experience is with the oil-fed tensioners, which do. I kept the pin on my keychain, which came in handy when I had to rebuild the motor.
Dru 1980 911SC Targa Petrol Blue Metallic Cork special leather Sport Seats Limited Slip 964 Cams SSIs Rennshifter 1990 250D Opawagen 1995 E220T Sportline Familienwagen 1971 280SE Beverly... hills that is 1971 Berlina 1750 Faggio |
if you dont have the pin the trouble is finding something that wont break once you put it in.
i dont think it was a 911, but i tried putting a drill bit, an allen wrench and other things in there and they all broke.
Wer bremst verliert
Nice hack.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
Great and cheap (3.99) toll .
RDM -- the non-oil fed tensioners do not feature the pin. There is a wire "clamp" that was probably thrown away when it was installed in the factory. I have seen threads where people found these or made their own -- but I like my spring clamp, and now I have an extra clamp around the workshop for other uses.
