-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   Differential housing joint flange play (http://forums.pelicanparts.com/showthread.php?t=835396)
Wew 10-23-2014 09:25 AM
Hi all,
In the middle of my transmission refresh, and replace the seals in the differential.
Now that I have things back together I notice on the one side I have .6mm of in and out play. When I look at the pelican parts catalogue one image has the main stretch bolt going right in to the joint flange. The other image has that same bolt with a washer.
When I took it apart I do not remember there being a washer, nor do I remember the slight in and out play.
I have attached pictures of what I am referring along with the side. The other side of the differential has no in and out play.
Thanks,
GarySmileWavyhttp://forums.pelicanparts.com/uploa...1414085103.jpg
http://forums.pelicanparts.com/uploa...1414085116.jpg
http://forums.pelicanparts.com/uploa...1414085129.jpg
