HAH HAH is offline
Porsche Crest Noise from the 930 CIS Monster engine
I have a question regarding the "creaking" noise with the Porsche 930 3.3l Turbo CIS Monster engine. The sound occurs is more common when the engine is warmed up, (gear on or idling doesn't matter). The sound is in the most simpliest frequency like one when you would throw nut into a metal can. If it's warmed more like in demostration.
Demostration video via following link: https://youtu.be/p7AgKkqvFLI
Otherwise the engine and the car works perfectly. Maybe the turbo boost is not quite like it use to be and feels like the cylinders not getting enough fuel after 1,1bar pressure.
I have checked all the air hoses, turbo air propeller axle, by-pass, wastegate, spark plugs and cables and everything seems to be ok. Also all of the visible fasteners.
You guys have any idea from where the sound might come and what could be
the issue?
I would appriciate any advce since in Finland the driving season is quite short and I still have a time to get it fixed before next garrage season
Old 07-04-2016, 01:33 PM
T77911S's Avatar
that sounds like a relay or something other than an engine mechanical part.
nice smooth sounding engine.
were you making the RPM's change or was it doing that on its own.
again, great sounding engine.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 07-05-2016, 06:56 AM
HAH HAH is offline
Thanx it's even better without that "not so good noise" �� My associate was throttling the gas lever during the demo and rise the RPM's. Any other diagnosis than relay sound?
Old 07-05-2016, 07:05 AM
https://www.youtube.com/watch?v=yoxnN2Nh0Lc
In this video you posted, the fan pulley looks like it wobbles a bit, especially when you give it throttle. Maybe the fan nicking the housing?
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 07-05-2016, 08:10 AM
Laneco's Avatar
That REALLY sounds like the fan blade just nicking the housing. With the engine off, I would look for scraped off paint/coating on the housing. When I've had them nicking - it's usually on the bottom but I did have one that contacted on the top around the 11am position.
That said...wow this car looks absolutely badass!
angela
Hello
Old 07-05-2016, 11:44 AM
HAH HAH is offline
I have checked the fan housing and unfortunately there aren't any worning of coating or paint in there.
Someone must have had similar symptoms than in my demostration video: https://youtu.be/p7AgKkqvFLI
Any other route causes?
Old 07-06-2016, 01:13 PM
I'm a NFG but it could be the dump valve gaskets being worn. If not get a cheap stethoscope and move it around to see if you can isolate the click sound.
If it is the dump valve this could help:
http://forums.pelicanparts.com/porsche-911-technical-forum/71370-changing-930-dump-gaskets-pictures-galore.html
Old 07-06-2016, 10:20 PM
HAH HAH is offline
That could have been the cause but not with this 930, because there is no dump valve. Only diverter valve (by-pass) which I have checked. Although the noise is similar than some dump valve videos that I found in YouTube. Thank you anyways for the quality link!
Any other hints what could be the noise source?
Old 07-07-2016, 11:05 AM
T77911S's Avatar
does it only do it when you rev and let off the gas or will it do it at a steady RPM
RACE CAR:: sold
Old 07-07-2016, 11:40 AM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
That sounds like a combustion leak to me. Does the engine have the original dilivar head studs? Regardless, it would be worth your time to remove the lower rocker covers and take a look.
Old 07-07-2016, 12:16 PM
Registered Loser
My fan blade has nicked the housing and that's exactly what it sounded like.
Current Rides:: 1987 Red 911 Targa, 2007 R320 CDI, 2003 Red Dodge Ram Hemi, 1993 Beater Jeep Cherokee, Airbus A320
Gone but not forgotten: 1981 VW Scirocco S, 1989 Honda Accord Coupe LXI, F-16C (still my favorite vehicle!),MC-130P, C-130E, T-38, T-37, C150, C172, PA180
Old 07-07-2016, 12:21 PM
HAH HAH is offline
It's doing it only when rev and let of. Not in the steady RPM. The head studs should be the stronger ones. Can that kind of noise come from the broken head studs?
Old 07-08-2016, 11:01 PM
Look harder at the fan housing, it's a barely there sound. Loosen the fan strap a little and see if it quits or changes
Old 07-09-2016, 12:03 AM
check the belt on left side is not touching something when u rev. it moves at same frequency as chirp..
Old 07-09-2016, 01:52 AM
Doesn't that sound like the plastic rings in the diverter valve are shot. Each ticking noise is perfectly in sink with the throttle blip. Should pull the covers and replace the plastic rings.
Rahl
Old 07-09-2016, 09:40 AM
Remove the fan belt, start the engine, and rev it a few times, [no more than about 40 sec] If the noise is gone, its fan or pulley related.
Hope this helps.
A...
"But instinct is something which transcends Knowledge
We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile"
Nikola Tesla
Old 07-09-2016, 10:51 AM
Forced Induction Junkie
WERK I's Avatar
How old is the fan belt? When they get up in years, the belt becomes hard and will actually sound like metal to metal contact. When the engine is warm as in the video, take the fan belt off and run for 30 seconds.
Other places; crank and fan pulley's, alternator bearing, blow-off valve not seated or defective(if you have one) or recirculating valve defective.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 07-09-2016, 01:11 PM
HAH HAH is offline
The fan housing is just painted and seems ok and the alternator belt is quite new, so I don't think that those are failing.
My plan is now following:
1. Drain the motor oil and check if any metal particles there
2. With the previous step confidence change the BOV, drive engine warm and test 30-45s without the fan belt. If not change to noise then proceed to step 3.
3. Remove the heat exchangers and the lower exhaust valve covers to see if any damaged to head studs and cumbusion leak there?
Will update my findings to this thread.
Pls. still advice welcome what components to check?
Old 07-15-2016, 05:40 AM
ELZ's930's Avatar
As stated remove the belt and give it a quick test. Check the spark plug leads to make sure there is no jumping spark under initial load.
Sent from my "Driving Shoe Phone"
the911den.com
Instagram / UberPorsche930
https://www.youtube.com/channel/UCg4ZbACRJsODXgnlMVZsjEg?view_as=subscriber
Old 07-15-2016, 08:19 AM
T77911S's Avatar
Rahl
diverter valve/BOV
the DV will be open at idle due to vacuum. when you rev it the vac goes away and the valve will close then open again when you let off the gas.
its not the fan housing.
RACE CAR:: sold
Old 07-15-2016, 08:47 AM
Tags
930 3.3 turbo , cis , engine , noise
