7-31 R&P for a 915
Hello everyone. I have this ring and pinion. It is a 7-31. Can anyone tell me if it is for a 915 or a 901?
Thanks John ![]() ![]()
gearhead
901. If you look on the parts closely there should be 11 digit part numbers and a pro date (2 digit month and 2 digit year with a logo between them).
I will look for those numbers. But this looks like a 901 R&P?
Thanks John |
Racer
I understand. I will confirm with the numbers he spoke of.
Thanks for the help, John |
gearhead
See the difference in the nut end of the shaft?
FVD Brombacher Online Shop - 91530291117 - ring and pinion 8:31 (for 915 gear box) - |
the roller bearing is an instant giveaway.
I can see what you are talking about. The date is 8 69. Aug 1969.
Also I see the difference in the threaded end of the pinion shaft, and note the roller bearing. Thanks for the help guys. John |
