Cold Control Pressure When It's Coooooooold Out
As some of us aren't lucky enough to be in summer temperatures year round, it makes checking the cold control pressure interesting.
In the Bentley manual, they only have the corresponding control pressure graphs limited to a minimum of 10 degrees Celcius where for my 80 SC, is 1.5-2.0 bar. What happens if the ambient temperature is lower than 10 degrees Celcius when you perform this test? Is the CCP a linear relationship at points below this graph? Or is it a constant where my CCP should be 1.5-2.0 bars at say 0 degrees Celcius. This came up as I was checking my fuel pressures when it was 0 degrees Celcius out and saw 0.85 bar. I have a feeling that my CCP isn't set properly but until it warms back to 10 degrees, I can't really verify. My theory is that the deflection of the bimetallic strip reaches a certain point and stops, so it should be linear till that point. But what is that endpoint? If the graph leads us to believe, then perhaps endpoint is wherever the standard deflection is at 10 degrees? Here's Tony's (boyt911sc) reply to my query, would be interesting to hear other Pelicans' feedback! Quote:
Crotchety Old Bastard
Experimenting with worn out WURs is meaningless. The graph supplied in the Porsche factory repair manuals displays the spec versus temp range. Beyond that range is a steep curve of diminishing returns. The cold pressure bottoms around 1bar as hydro-lock or flooding the cylinders is approached.
