-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   extrude hone alternatives? (3.2 intake) (http://forums.pelicanparts.com/showthread.php?t=855803)
gliding_serpent 03-12-2015 06:55 PM
I understand the concepts behind the benefits of extrude hone, and I understand that it would only benefit when the air need of a cylinder exceeds the capacity of the plenum with the poorest flow (assuming there is not a more significant upstream bottleneck). I.e is is of benefit in cars with more power, and presumably other upstream intake mods.
So my question is, has anyone mimicked this process (the original process uses abrasive clay) without cutting open the intake, polishing, and then re-welding? i.e. has anyone mechanically polished the intake with a flexible abrasive device like a metal brush (think chimney sweep for lack of better terms).? Sure it would be imperfect, and challenging in the plenum bends, but I am just trying to think about a feasible alternative that does not involve 1K after shipping my plenums across the continent.
With the right gear, you could still flow match, and even if you did not, blindly polishing all plenums, even a bit, would improve flow rates and at least raise that ceiling where the cylinder air demand exceeds the capacity of the plenum with the poorest flow.
Another way to look at this is, for those that had an extrude hone flow report, which plenum/cylinder had the lowest flow pre hone? I know people report differences as high as 30%. I suspect there will be a pattern there as some are further from the throttle body than others. My logic here would be the "poor/lazy mans solution" to hone out only the plenums with the lowest expected flow. Again, raising your ceiling. Sure, you would not know how much you raised it, but you would.
thoughts and experiences would be appreciated. This is an exercise in mental masturbation as much as anything.
Pstallo 03-12-2015 07:26 PM
After 'extrude honing' was referred to me as an option, I tried to figure out what it meant and was unsuccessful. So, I began looking into something I DID understand, which was displacement. My current exploration is in obtaining a 3.6L engine. That's actual HP. The 'extrude honing' sounded like voodoo to me.
I would, however, defer to someone who actual figured out what 'extrude honing' is and whether or not it produces real horsepower.
gliding_serpent 03-12-2015 08:01 PM
I am going to 3.4. As you know an engine is an air pump. To make more power you need more fuel, and more air to match. The more air you can get into the combustion chamber, the more fuel you can add for increased power. The more power the engine produces, the more demand it puts on the intake. Eventually, the intake needs to be opened up (usually limitations are seen in high rpm's where air flow needs are higher). Extrude hone is one way to open up or at least improve the efficiency of the intake. I don't see a lot of value on it's own as other intake factors will limit things first, but that is getting off topic anyway. Same for the 3.6. I know the benefits of that swap, I am just trying to reason a "poor means extrude hone".
What would be interesting is to know the flow rates of each plenum, and then calculate the flow demands of each cylinder given a set hp. You could then go through the entire intake calculating rough flow rates based on cross sectional area and determine where the restrictions are largest. You open that up. It would be interesting what flow rates (engine hp) would be required before the plenums (extrude hone) actually become the bottle neck.
Dogma from some folks around here is that the airbox is the low hanging fruit of intake limitation. That is why cone filters or open airboxes add power on the top end. Another is the AFM itself. Another is the throttle body, and finally the plenums. I suspect the plenums themselves don;t become a significant restriction until engine hp becomes quite significant.
will hung 03-13-2015 05:13 AM
I think you are right here.
My understanding is that there are far greater intake restrictions upstream of the plenum and until they are addressed, there isn't much benefit to extrude honing the intake. But a big benefit is balancing the flow between cylinders.
So I would love to see what people found in regards to flow per cylinder. These intake plenums were cast, so there is a strong possibility that the flow indifference is a result of the mold and could be repetitive. So one could say, work on improving the flow of a single cylinder to balance things out.
gliding_serpent 03-13-2015 05:38 AM
Exactly! It would not be as ideal as extrude hone, but would give most of the benefits if you could polish the offending "slow" plenums.
3literpwr 03-13-2015 05:50 AM
See here... Porsche 911 SC Carrera Machine Work - European Cars Magazine
gliding_serpent 03-13-2015 07:45 AM
Thanks for that link. Pretty clear 1 and four are down on flow, which mskes sense given they are furthest from the throttle body. 2 and five are closest, so have the best flow, and 3 and six are in between.
Will be interesting to see more examples to see if this pattern holds up.
Do the low hanging fruit would be to polish 1 and 4. Too bad, as they would be the hardest to reach from the top.
gliding_serpent 03-13-2015 07:52 AM
#1 277 351 (numbers are flow before and after)
#2 280 349
#3 280 351
#4 295 351
#5 286 349
#6 289 352
gliding_serpent 03-13-2015 08:03 AM
This is the data from the linked article above
#1 - 197/322 +125 CFM gain
#2 - 313/335 +22 CFM gain
#3 - 227/331 +104 CFM gain
#4 - 197/348 +151 CFM gain
#5 - 313/339 +26 CFM gain
#6 - 233/335 +102 CFM gain
gliding_serpent 03-13-2015 08:16 AM
1 257.1 290.3
2 253.2 298.4
3 250.9 297.7
4 264.7 294.6
5 250.4 300.6
6 260.8 297.1
Allan Kelsey 03-13-2015 08:18 AM
Exhaust port image
I had opportunity to remove my exhaust recently and it gave me a chance to look at the exhaust ports, here are 2 pics of #1 & #4. Is the difference in burn color attributable to the constricted flow through intake?
http://forums.pelicanparts.com/uploa...1426263430.jpg
http://forums.pelicanparts.com/uploa...1426263457.jpg
gliding_serpent 03-13-2015 08:32 AM
Of interest, not everyone has a lot of variability of flow between plenums in stock form. Thus, to eval need, it might first be best to flow test the plenums.
Two out of the three plenums above have what i would call statistically insignificant differences in flow out of the box.
I wonder if early vs late castings had variations. Maybe they identified the issue at the factory and corrected the design for the later 3.2's...
gliding_serpent 03-13-2015 08:34 AM
Allan, many factors could be at play. I will go on a limb and speculate that in a stock engine, the plenum flow will not play a part in what you see.
gtc 03-13-2015 08:43 AM
How about just adapting a plastic 964 intake?
gliding_serpent 03-13-2015 08:53 AM
I read about that with the adpators. Would be light... But i like the oem look.
rfloz 03-13-2015 10:43 AM
Originally Posted by will hung (Post 8528323)
. . . a big benefit is balancing the flow between cylinders.
Does Extrude Hone actually claim to balance the flow or do they just run the abrasive through all ports and call it a day? Do they provide before and after flow numbers for each port?
If anyone wants to get really ambitious there is info out there on building your own flow bench. I haven't seen it in Pelican, but I know Hot Rod magazine had an article a number of years ago. Then, you could experiment with porting using old fashioned abrasive tools powered by a hand drill with a flexible shaft to which the abrasive wheels are attached.
turbobrat930 03-13-2015 11:45 AM
Originally Posted by rfloz (Post 8528883)
Does Extrude Hone actually claim to balance the flow or do they just run the abrasive through all ports and call it a day? Do they provide before and after flow numbers for each port?.
To answer your question, yes. I had my done years ago. When I did mine, there was a HUGE discussion about several of the ExtrudeHone locations not doing the job correctly. In the discussions (way back when), it was found that the location that did the best work was the one in Wisconsin.
I sent mine off to the WI location, and within 2 weeks I received mine back. I had paid the extra $60 or so to get the before and after flow results. The intake came with a computer printout of the before and after results. It didn't increase a lot, ( maybe 60 CFM or so...) But, what it did do was even out the flow between ALL of the runners to within 10CFM. Before, there was a disparity of which the greatest was 80CFM.
That might not make a difference to a person with a stock engine. But, with mine pushing over 800HP and running on the ragged edge, I didn't want to lose an engine because of an imbalance.
They do have a good process. Its a media that contains walnut shells. When they force it through a part, it flows through it like water. (water takes the path of least resistance), so it only really takes away metal at the point of the most restriction. It really doesn't open it up much, just makes it flow better, and equals everything out.
gliding_serpent 03-13-2015 01:01 PM
All the numbers were before and after that i copy/pasted from other threads.
JeremyD 03-13-2015 05:36 PM
I did mine too when I did my 3.4 - per Steve Wong - the biggest difference is above 5,000 rpms and the absolute difference is only about 7 HP above 6,000. THE biggest benefit is evening out the flows of the runners - mine too were off close to 20% so it definitely makes sense to try and even things out especially as you try and optimize your engine.
Tippy 03-13-2015 05:53 PM
After 'extrude honing' was referred to me as an option, I tried to figure out what it meant and was unsuccessful. So, I began looking into something I DID understand, which was displacement. My current exploration is in obtaining a 3.6L engine. That's actual HP. The 'extrude honing' sounded like voodoo to me.<br>
<br>
Extrude Hone is far from voodoo. It mimics actual airflow by using a paste with abrasive particles pumped through the passages.
Tried and true for decades.
gliding_serpent 04-25-2015 04:44 PM
I got my plenums back from my local machine/performance engine shop. I was curious so had it flow tested. The owner of the shop did the flow testing, and was polite, but not impressed with the results (they make highly tuned and blueprinted vintage muscle-car and dragster engines).
I was initially impressed that things were pretty close, until i saw cylinder #6.
http://i1168.photobucket.com/albums/...psqzqrzdnz.jpg
#1 261 CFM (cubic feet per minute)
#2 251
#3 252
#4 245.5
#5 248
#6 238
Lets run some numbers...
- The largest spread is between #1 and #6: 23 CFM. That is a near 8.8% difference.
- The mean CFM is 249.25.
- Thus deviations from the mean are as follows...
#1 +4.7%
#2 +0.7%
#3 +1.1%
#4 - 1.5%
#5 - 0.5%
#6 - 4.7%
Now, my engine will be punched out to a 3.4L (actually 3367cc, or 205.47 cubic inches). Lets calculate the total CFM demands of my engine...
- max rpm (6760) x cubic inches (205.47) = 1,388,977.2
- 1,388,977.2/3456 = 401.9
- 401.9 x 0.85 (presumed volumetric efficiency) = 341.6CFM
- Thus, an ideal intake should provide about 342CFM to meet my 3.4L engine's intake needs. In other words, 56.9CFM per plenum!!!
- My intake (at the plenums) provides 249.25CFM on average per plenum. The worst is 238CFM (#6). That is still over 4 times the flow needs of the cylinder at max rpm.
Such info in my mind suggests that extrude honing of the plenums makes little difference if any, as this simply is not an area of flow limitation... not by a long shot. This would support an opinion shared by me from a well known tuner that they had never seen dyno proof of gains from extrude hone.
I welcome thoughts, counter-points. I will also look to see if there is a more accurate way to estimate the total CFM needs of an engine.
LJ851 04-25-2015 05:57 PM
That is not how it works, only one cylinder pulls at a time.
gliding_serpent 04-25-2015 06:21 PM
I have taken discussion here... http://forums.pelicanparts.com/porsche-911-technical-forum/862450-3-2-intake-plenum-flow-testing-interesting-results.html#post8594915
