Hot Plugs and Carbs
Presently running a neutral plug, WR7 DC+ Bosch . PMOS running a little rich, spoke with Richard at PMO and he suggested maybe a little hotter plug. Anyone out there tried, thinking WR8DC or NGK BPR5ES. Engine is hot rod, Pistons cams etc
82 SC Twin Plug 3.2 SS ,46 PMO
83 911 Production Cab #10
Contact NGK, give then your spec and they will recommend a plug. They answer within 30 minutes using their contact form: NGK Spark Plugs USA
For my stock 3.2 (no internal mod) with PMO EFI using Electromotive TecGT they recommended BPR6EIX 6637. I was running rich using using the WR7DC+ Unfortunately, I won't be able to try them for another month.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
how do the plugs look when pull them?
are you fouling plugs? how do you drive the car? if fouling then run a hotter plug. if racing run a colder plug. if city driving or idling a lot run a hotter plug. a "hot" plug is really only needed for idling and startup. if a car was only driven at hiway speeds you could run a very cold plug. look at it this way, the temperature range of the plug is what keeps it clean. it has to stay clean to keep from fouling. if you are not fouling them then you are probably OK but this can also depend on my other questions and how they look. hopfully this will help YOU decide on what you need
I've run both the plugs you mentioned on MFI and carbed hot rod engines. Prefer NGK over Bosch.
This may help as well;
How do I "read" a spark plug?NGK Spark Plugs USA Why are there different heat ranges? NGK Spark Plugs USA Heat Range: NGK Spark Plugs USA
Thanks for you input
More like Dry Fouling (carbon) PLUG STUDIO / NGK
NGK BPR5ES burn clean in my motor.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
fix the AFR. also could be timing. maybe not enough advance at that RPM
i dont think i would go hotter.
