Convert '72 oil tank to 964/993 fill?
My car is a '70 911 coupe and I would like to retrofit a '72 oil tank but I don't want an oil door on the rear quarter, so I wondering whether it would be possible to make modifications to the '72 tank for 964 style fill?
How are 964/993 tank filled? From the bottom? Does it use a pump for filling? Thanks. |
The oil filler on the 964 is in the engine compartment. It has a tube that connects to the oil tank.
![]() john |
![]() 964 oil system ![]() ![]() ![]() 993 oil system, adapted into a 930 ![]() ![]() ![]() ![]() ![]() ![]() The main difference between 964 and 993 is that the 993 has an oil filter at the bottom, the 964 has it in the engine compartment
Thanks for the replies and pictures.
What I'm asking - can an actual '72 tank be modified to work in conjunction with a 964/993 filler neck in the engine compartment? i.e. Can an inlet be welded at the bottom of the '72 tank for the filler tube? Last edited by blue72s; 11-28-2023 at 11:39 AM.. |
the large main on is under the oil tank the smaller secondary one is where the oil cooler would be on an older 911 engines. The main one is on the scavenge side of the pump and second on the pressure side an issue w/ the '72 tank is it's small size All the tank conversions i've seen use 964 or 993 tanks, the 964 seems to be the more straightforward one
A door jam filler neck is another option. I am putting a 993 tank in my car as they are all stainless construction vs. the 964 or ‘72 and in my mind that makes it easier to modify…….. I wouldn’t necessarily recommend it though. It’s a ton of work at least the way I’ve gone about it with dubious benefit.
Why would you want to retrofit to a 72 tank? Is it a track car and you want to move the oil tank forward of the wheel for balance? My 72 had a g body tank in the engine compartment but the 72 oil
door remained. When I did my recent restoration, we went back to the 72 tank and piping. It was not easy. If there is no aesthetic reason (ie cut a hole for a singer like filler neck on the quarter), perhaps keep it stock. Sent from my iPhone using Tapatalk
996 Coupe, 84 Euro Carrera, Cayenne S, BMW CS 30, 72 2002 Ti (gone) 72 911 Hot Rod, Healey 100M, Giulia 1300 Ti, Merc 280SE4.5 Colorado Grand 03-04-05-07-08-11-17-18 Tour Auto 04-05 RG #650 |
The main reason is heat.
Quote from Tyson Schmidt in another thread many years ago: Quote:
Heat or no heat, it’s a ton of work and money and messing around for very small gains unless you really want to do it for exhaust clearance or turbos or some other packaging reason.
On a street car the weight distribution difference is minimal and any difference in heat in the oil can be over come with a slightly more efficient oil cooler setup. |
Agree-I installed finned elephant racing oil lines to my front carrera cooler. Car runs at perfect temp (built high comp 3.4 with the 72 tank) Sent from my iPhone using Tapatalk
