targa top uncliped on front
I notice that when I install my top, at the first bump in the road that flexes the car at all, the middle front roof clips which hold the folding front strut disengage
Recommendations please
Old 10-25-2015, 09:41 AM
Vintage Owner
Jack Stands's Avatar
There is some adjustment available in those clips. Slightly loosed the screws, try to shift them over and re tighten. It's also possible that the cloth holding the roof panels in place may have deteriorated and they're no longer aligned properly. In that case, time to give Dan a call (CarsInc.com).
However, it's best to just drive with the top off!
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 10-25-2015, 11:00 AM
There are longer clips available. Make sure the frame has not been worn away.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 10-25-2015, 11:12 AM
where I can buy the longer clips
Old 10-25-2015, 12:14 PM
I bought mine from this site..but I see they are now NLA. Call the parts dept and maybe they can tell you what to do.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 10-25-2015, 01:59 PM
Discseven's Avatar
Hyper... The backing plates that the screws screw into float on the other side of the roof plates. These backers may stay in place when the 2 screws are removed if the roof is not moved but... they can get "lost" in the roof if the roof is moved/tilted. Suggest always having one screw & washer in the backing plate to prevent them from getting lost.
As Jack mentioned, there's some adjustment provided in the roof plate to tune hook positions. In the event longer hooks do not suffice, grinding the holes in the roof plates to allow the screws more movement in the roof plate is the answer. Notice there is rise in the roof plate preventing the backing plate from a great deal of movement towards the center of the roof (which is always the direction needed to tighten the hooks to the roof.)
A backing plate in position...
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 10-25-2015, 02:09 PM
