fuel lines - fuel head to WUR
Are theses lines plastic underneath the rubber? I am thinking about replacing them as the motor is out right now and they may be original. Who carries these? Our host only has one of them. They were not leaking before I pulled the motor but trying to do some PM.
they are hard plastic.
i have replaced one. if you are not having problems i dont think i would goto the trouble. if you can check the fule flow out of all 6 at one time , that is a good check for the lines and injectors. one of my lines was defective. the lines slide onto the barbed end pf the fitting. i had to lube the line with something. dont remember for sure, may have been dw40 or baby oil. (dont ask). then let the lines sit for a few days. i think i tried to twist the fittings and could not. doing 12 will be very hared on your hands.
86 930 94kmiles [_ ![]() 88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_ ![]() 01 suburban 330K:: [_ ![]() RACE CAR:: sold |
