After market oil cooler?
Anyone have any ideas what this bar is?
I would like to replace or repaint if I can't get a replacement for this part as it is rusty and has a dent.
Old 10-28-2015, 04:31 PM
Undocumented User
McLaren-TAG's Avatar
It's a nerf bar to protect the AC condenser, it bolts right off an you can blast/refinish it. It's thick as hell so I doubt it would need to be replaced.
Old 10-28-2015, 04:36 PM
911SC Tinkerer
merlinfe's Avatar
Chin spoiler also covers it right up.
-'83 911SC Coupe
SSIs, Dansk GT3, EFI ITB, Instagram: @ Zinnmetallic_sc
Old 10-28-2015, 07:40 PM
GeorgeM's Avatar
... which you should have to complement your rear spoiler, for aesthetics and aerodynamics.
George M
'89 Carrera 3.2
'91 928GT
'76 914
'18 Macan GTS
Old 10-29-2015, 08:28 AM
Fleabit peanut monkey
Bob Kontak's Avatar
+1
At speed (100mph and over) the set makes a nice difference. A few hundred pounds of lift reduced.
If you just putt around the imbalance should not be an issue.
1981 911SC Targa
Old 10-29-2015, 09:08 AM
Thank you for the help, looking at the front spoiler kit now.
Old 10-29-2015, 02:40 PM
If you do decide to remove and re-paint, which I did, here are a couple of pointers for what it's worth...in addition to the two bolts under the car, there is a nut you need to access from the luggage compartment and remove to get this bar off. When I did get mine off, I initially tried bead blasting with limited success, as the coating was very thick similar to a spray on bed liner. Have a grinder ready to get this off. Then you can bead blast and coat per your liking.
Old 10-29-2015, 03:16 PM
