For those that don't wish to make a permanent modification to their cars by welding brackets onto the tub, can you comment on a second bar, say one that is run from the right hand strut area to a bracket on the tub floor, where the brake booster is located on the later cars?
Would that not eliminate most of the issues with the degree of freedom of the main bar attachment points at the strut tops? JR |
Frankly the price they are asking is sensible as if you have 20 pairs cut and folded there is a decent margin at this price. I will have brackets in about 10 days and would be happy to sell them for the MH Teile price. |
With all due respect (this wasn't my original point), it seems your post above is contradicting your earlier post? I agree that heim joints < bolts < welding but now you are saying that the bar's diameter is more important than the end condition. I agree diameter makes a big difference in the second moment of area but the slenderness ratio is still quite high and if we go with the textbook Euler buckling formulas the critical load increases by a factor of 4 when going from a pin-pin connection to a fixed-fixed connection. I suppose this same change does only require a <50% increase in diameter so I can see why you say diameter is more important. Just seems like the end still count for something significant. My original point was just that the bar's fixing is different in the transvers and horizontal planes. It is not that hard for the ends to rotate around the bolt axes just as a heim joint would. The bar will buckle in that direction even if it is totally restricted in the other planes. |
Todd |
| All times are GMT -8. The time now is 05:56 AM. |
