You're going to run out of gear and he will not.
2007 GT3 1982 911SC 1998 Integra Type R |
I think Mike said Im limited to 183MPH@7300RPM with the current gearing. LOL, trust me, she lifts at 125MPH, I wont be seeing anywhere close to 183MPH with out some serious aero upgrades.
16 Boxster Spyder (sold), 82 911 Wide body/Miami blue/Mike Bruns built 3.6 (sold), 80 911SC Black/tan (sold), 87 930 Turbo 505 slant GP white/black (sold), 95 993 C2 GP white/tan (sold), 82 911SC Hot Rod lightweight Black/black (sold) |
New oil cap, mine was looking a bit rough. The engine bay should be pretty once the motor is back in there. Also got new differential bolts (12). The Guard LSD uses 928 length bolts, hence the 928 part #.
16 Boxster Spyder (sold), 82 911 Wide body/Miami blue/Mike Bruns built 3.6 (sold), 80 911SC Black/tan (sold), 87 930 Turbo 505 slant GP white/black (sold), 95 993 C2 GP white/tan (sold), 82 911SC Hot Rod lightweight Black/black (sold) Last edited by nippy; 04-09-2019 at 01:40 PM.. |
Just remember. Years ago I talked to a tire shop. He said he made more money than he ever did in the shop since they came out with the low profile tires. Why? The low profile tires bent the rims in pot holes and that meant a wheel replacement. Ha Ha.
Kent Olsen 72 911 SCT upgraded 3.0L McMinnville, Ore |
he is 4.5 lb per hp
your car is 6.4 lbs per hp so his power to weight is roughly 30% better. |
power to weight ratio is a curious thing.
my brother has ZL1 camaro. 4000 lbs. and 650 HP. i have a 2000 lb. 914 with close to 300 HP. modern nannies aside, similar power to weight ratios, vastly different driving experiences...
1971 914-6 GT 3.6 1974 911 1976 911S leaf green backdate 3.2 |
Garage goals fellas!
Thank you to my buddy who likes to remain behind the scene...his cars speak for themselves and the "illness". Im very sick as well, just don't have the funds. GT2RS 700HP/553TQ 3241 lbs Ferrari 812 788HP/529TQ 3593 lbs Porsche CGT 605HP/TQ435 3043 lbs WINNER TO ME???? The one with 3 pedals!
16 Boxster Spyder (sold), 82 911 Wide body/Miami blue/Mike Bruns built 3.6 (sold), 80 911SC Black/tan (sold), 87 930 Turbo 505 slant GP white/black (sold), 95 993 C2 GP white/tan (sold), 82 911SC Hot Rod lightweight Black/black (sold) Last edited by nippy; 04-10-2019 at 10:17 PM.. |
Spinnin' ain't Winnin'
Derrick |
Tranny ready to go back together.
16 Boxster Spyder (sold), 82 911 Wide body/Miami blue/Mike Bruns built 3.6 (sold), 80 911SC Black/tan (sold), 87 930 Turbo 505 slant GP white/black (sold), 95 993 C2 GP white/tan (sold), 82 911SC Hot Rod lightweight Black/black (sold) Last edited by nippy; 04-16-2019 at 04:07 PM.. |
The car had so much dust on it, I had to wash it. I cant wait to get back behind the wheel!
Almost
Schleprock
Missing “loose” 2nd gear and the 1-2 shift sleeve????
Kevin L '86 Carrera "Larry" |
Yep Mike found some issues with 2nd gear and had to take apart and replace Last edited by nippy; 04-22-2019 at 07:27 PM.. |
Can you notice the difference in the LSD?
Havent got it back yet
915
It’s still in mock up stages, there’s a gear noise turning it through and in the process of elimination, the second gear set was the problem, I am guessing it ran a long time with the bearings loose and now that it’s tight center to center it wasn’t happy
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago. |
Schleprock
Just giving nippy a hard time. I suspected it was in prefinal assembly process.
Great observation from Mike on the gear noise during assembly. That's not a talent you're going to find very often. Mike will also set you up with a nice 2nd gear for sure. He sold me a very nice 18:33 2nd gear set for my needs awhile back.
Swchweet build porn for sure.. car has come a long way this time around!
RGruppe #180 So many cars.. so little time!! |
