Send a message via AIM to tmblackflag Send a message via Yahoo to tmblackflag
Moaning tugboat sound coming from front right wheel
For the five years I've had my car I've always heard this sound. It happens when I brake to a complete stop and then roll forward slowly with my foot off the brake. It is worse when colder out.
I've replaced the calipers and bled the brakes. I don't believe the caliper is dragging and causing the noise and don't see any unusual wear on the rotor. The sound goes away if I tap the brake pedal.
I'm thinking it might be the wheel bearing going out as they are still original. Has anyone experienced this? The car has 100k miles.
1986 3.2 Meteor Metallic Grey
Old 01-09-2016, 04:31 PM
After doing all that you did and changing the hoses mine does that also
Rick
88 Cab
Old 01-09-2016, 04:54 PM
Senior Advisor
James Brown's Avatar
pull the hubs, change the bearings, both sides, and seals, easy peasy. You already ruled out the brakes, not much left. Host has all the parts
08 Cayenne Turbo
Old 01-09-2016, 04:59 PM
Did you experience these symptoms also?
Rick
88 Cab
Old 01-09-2016, 05:01 PM
Recreational User
porschenut's Avatar
Those are the classic symptoms of a bad bearing. And after 100k miles, they are most definitely in need of replacement. Do both sides, inside and outside bearings and races.
Old 01-10-2016, 08:37 AM
But if you coast to a stop and take off no noise. How is that the classic sign of a bad bearing?
Rick
88 Cab
Old 01-10-2016, 08:42 AM
ted ted is online now
likes to left foot brake.
ted's Avatar
Could the master cylinder to brake pedal check rod be adjusted a bit too long?
There by dragging the brakes slightly?
Does your brake pedal have free play at the top before it engages the master cylinder?
Sometimes weaving back and forth can help replicate a wheel bearing noise.
Trying to figure exactly which wheel bearing is making the noise can be difficult.
Old 01-10-2016, 09:00 AM
Can I check that by stepping on the brake and seeing what the play is? How much should it be?
I'll go out and check when I put cloths on. It is only 6 deg here.
It only makes a moaning noise for about a second as you pull away from a stop after releasing the brakes. I've just lived with it but I did try to fix it once like the original poster and if I knew what it was I would definitely fix it
Rick
88 Cab
Old 01-10-2016, 09:20 AM
That doesn't sound like a wheel bearing to me. Typically they have a constant moan at moderate speed and change pitch when lightly turning left or right.
I bet it's still something brake related. Mine have done something similar but only when changing direction, say rolling backwards with brakes on and then pulling forward. Mine's obviously the pads shifting.
'87 911 Carrera Coupe (go fast, small parts / small kids hauler)
'04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius")
Old 01-10-2016, 09:54 AM
New thought.... do you have the correct pads in the correct calipers? My thinking is you may have the wrong pad in their that's shifting enough to cause the noise after releasing the brakes and it moves back to it's static position.... just another thought.
Old 01-10-2016, 09:56 AM
ted's Avatar
This relates to my air cooled 911, can't speak for all cars.
Use your hand on the brake pedal to check the free play.
Measured at the top of the brake pedal it should have a half inch to 1 inch of free play before the check rod contacts the master cylinder.
I had incorrectly adjusted mine once with minimal free play and the pads could not knock back from the brake rotors.
That constant but slight rotor contact and extreme heat it created was visible on the pads being whitish and burnt.
Old 01-10-2016, 10:52 AM
Member 911 Anonymous
DRACO A5OG's Avatar
OP, PM me, I can take a look for you and let you know.
'85 Carrera Targa
PCA/POC
Old 01-10-2016, 12:29 PM
PM sent.
Old 01-10-2016, 05:43 PM
Replacement of bearings is so easy and cheap that I would do that simply to eliminate them from the mix. If the noise continues then go on from there. If you are not familiar with this simple DIY project you can see the step by step here. https://www.youtube.com/watch?v=9QcqqoDh2io
Old 01-11-2016, 03:25 AM
Sounds like the pads are dragging on that rotor. May be trying to hang up because your flex line is swelling shut and needs replaced. When you bleed the brakes, does fluid pass easily at that wheel? If not, replace the flex line. Does that rotor feel hotter than others after braking?
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 01-11-2016, 04:10 AM
Mine has done it for 15 years. I was told by our club members that it is the pads slightly contacting a slightly out of round rotor.
Never caused any harm.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 01-11-2016, 07:08 AM
moaning noise on turns
I believe it is the ball joints not the wheel bearings...
Old 01-12-2016, 03:16 PM
VMAX1's Avatar
My brakes were doing same noise. The retaining pins that you push thru the pads, that holds the pads in place, had a lot of dust build up. Used a wire brush to clean and rubbed some Sil-Glide on the pins. No more Moose moan. Here is a link of what I use.
NAPA AUTO PARTS
Old 01-13-2016, 07:57 AM
Put new brake pads, fixed my exact problem...Tim
Old 01-13-2016, 09:45 AM
Checked out
McLovin's Avatar
It's being caused by the brake pads dragging on the disc.
Why that's happening, you'll have to determine. The problem lies in the system somewhere between the brake pads and the brake pedal.
Old 01-13-2016, 02:47 PM
