Painting the Fan
I have run down numerous threads on re-finishing the fan and shroud. Several instances of both successful paint and paint not adhering to the magnesium fan. Some of the success stories note the use of VHT hi temp paint--makes sense. I am wondering about preparing the surface. My guess is that after cleaning, the surface should be given a light sanding to provide a mechanical "tooth" for the paint to lock on to.
Would appreciate confirmation or refutation from those with experience. Counter to this assumption are those who have polished the fan and then given it a coating of VHT clear. Maybe getting the fan super clean before painting is the secret.
Old 03-01-2016, 11:08 AM
Powder coat. Done it numerous times. Pick your color. I have always done silver/gray. Usually have to sand down ends of blades due thickness of coating. Very durable.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 03-01-2016, 11:23 AM
Here is a lower cost solution that worked out really good for me. I spray painted the fan using Seymour "Dull Aluminum" and did the housing in Seymour "Stainless Steel". This stuff really sticks after it cures and if it ever gets messed up, you can always re-do it without any drama.
Old 03-01-2016, 11:47 AM
My friends call me Phish
second on the powder coating. I sand papered the ends of the blades as well. I also left the area where the belt rides unpainted.
Old 03-01-2016, 12:59 PM
I love the idea of powder coasing but have a reservation. The way these engines get wet from the decklid opening, the fact that you have to sand the ends of the blades for clearance afterwords (leaving them bare magnesium), and that I live near the ocean....I would think the bare ends would start to corrode (in an area hard to see), and then corrode under the powder coat.....and by the time you saw the damage the fan would be useless. As I already have 1 fan/housing that is shot, and dropped an aluminum one that SUCKS....and cannot seem to source a good replacement mag fan/housing.....wouldn't paint be better? It is easier to repair yourself, the ends of the blades can stay coated (if you lay it on thin)?
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 03-01-2016, 01:58 PM
El Duderino
tirwin's Avatar
Well, you know I'm going to say ceramic coat and use Mark Motshagen...
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 03-01-2016, 02:01 PM
Well, if worried about corrosion of the blade ends after sanding, why not sand them before the powder coating? I don't live near the ocean but we do have a lot of humidity. Have at least 7 years on powder coated fan and no problems. Zip point zero. Nada. Tough stuff.
gary
Old 03-01-2016, 02:58 PM
Just had my housing and fan refinished my Mark Motshagen, great quality and a great guy to deal with
Before
After
'86 Carrera
Old 03-02-2016, 03:19 PM
bgyglfr's Avatar
I glass bead them and then clear coat. I like the bare finish. Another option is have someone like Shaun (tru6 on here) refinish it. He even refinishes the plating on the pulleys etc. Nice work from what I've seen.
70T 2.7RS spec.
68L coupe
Old 03-02-2016, 03:44 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Fan.
Glass bead & Satin VHT.
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 03-02-2016, 04:37 PM
As mentioned above, Tru6 refinished my fan which consisted bead blasting and clear coat. He removed the pulley and replated.
For the housing, I had it ceramic coated, which is thinner than powder coat. It is done in cast iron gray.
Old 03-02-2016, 04:39 PM
Senior Member
Jdub's Avatar
Flagging this post for engine porn.
'78 Targa in Minerva Blue
Old 03-02-2016, 04:45 PM
Before
After
What does something like that cost?
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Erik Schmid
Red Bus Brewing Company
Folsom, CA
www.redbusbrew.com
Old 03-02-2016, 08:26 PM
i live near the beach and haven't had a problem.
Old 03-02-2016, 10:04 PM
gtc gtc is offline
abides.
gtc's Avatar
I bead blasted mine, then spray painted with alumi-blast paint. Never had a problem with paint chips on the leading edge of the fan blades like everyone talks about.
Graham
1984 Carrera Targa
Old 03-02-2016, 10:17 PM
0396's Avatar
Now its just me, but when I see Honda Civic owners paint the brake calipers " red " like the original Big Reds. ..I just smile...as they want to copy / look like a Porsche Caliper.
What's wrong with the original color? Anyway just my .02
Old 03-02-2016, 10:21 PM
The Dude abides...
bigel's Avatar
Just a quick buff to the housing with metal polish and rattle can flat black...I'm happy with the results.
'03 Carrera 4S
Old 03-03-2016, 02:55 AM
flameon's Avatar
How do you get in touch with Mark?
Old 03-03-2016, 05:28 AM
Mots356@yahoo.com
1-949-463-2892
'86 Carrera
Old 03-03-2016, 06:32 AM
Call Mark to get a price. Every fan needs a different amount of work. I'll just say I think for the finished product his price was more than fair.
Mots356@yahoo.com
1-949-463-2892
'86 Carrera
Old 03-03-2016, 06:36 AM
