Bland
unclebilly's Avatar
Why is your coil so rusty?
Old 03-10-2016, 10:47 PM
ROW '78 911 Targa
timmy2's Avatar
These guys make a new harness for you. Me too...
https://www.************.com/p-1853-cdi-wiring-harness-3pin-75-77-models.aspx
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 03-10-2016, 10:58 PM
Not my coil or setup That is a picture of timmy2's setup testing a CDI tester. I like how the system is isolated and all wiring visible as it relates to ignition.
I need a wiring layout like this!
Old 03-11-2016, 07:26 AM
Is this the barest minimum wiring I need for my car?
Old 03-11-2016, 08:29 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
yes this will run the car
Not sure what (4) is. The tachometer connects to the green wire (points output)
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 03-11-2016, 08:37 AM
Do I need any other grounds? (Ie Coil doesn't seem grounded except to CDI Box) and I'm assuming dizzy is always grounded to engine block? (Or do I need to wire up a ground?)
Old 03-11-2016, 08:44 AM
T77911S's Avatar
yes dizzy is grounded to engine block.
I pulled mine and cleaned up all the metal to metal grounds starting at the points plate all the way to the dist shaft. it helped with the engine dropping out when I would set the timing and may have smoothed it out some.
you might ground the coil to the engine also.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 03-11-2016, 09:00 AM
The box will have to release a spark when the terminal with the arrow is shorted to the housing of the box (GND).
As mentioned before, the three pin CDI produces a spark when the points OPEN.
Given your postings, do you really rebuild these units or do you send them to the
actual rebuilder, e.g. Pelican Parts?
Dave
Old 03-11-2016, 09:35 AM
ischmitz's Avatar
I actually invented them
Old 03-11-2016, 10:56 AM
She runs!!
The 'braided' wires were throwing me for a loop but they are not needed! You can simplify the wiring as per the diagram above and she will run! (The wiring allowed for a spark at the points when they were opened).
It didn't fire, but I knew the points were rotten, changed them. Ran first turn!
Thank you to everyone who posted and contributed, I learned soo much. I know what most of the wires in the engine bay are/do and alot of the fuses (don't ask).
Old 03-11-2016, 02:42 PM
Same issue again, are my points the issue?
Old 05-31-2016, 12:31 PM
ischmitz's Avatar
Maybe the points need adjustment? Have you checked if they open and close properly?
Old 05-31-2016, 03:23 PM
Jonny H's Avatar
Originally Posted by Last911 View Post
She runs!!
You really ought to keep the shield round the trigger and coil lines. You'll suffer misfiring if any EMI / ESD gets in the CDI trigger input.
Some ideas on your non start:
I don't see a ground strap on your relay panel. 3 pin boxes need cases grounded.
The simplest non start issue I've seen was where the trigger signal wire was grounded because the insulation had failed and was touching the case.
New points are very poor quality.. Check the plastic foot hasn't split where it is riveted on. Sorted through a box of around 50 new Bosch points last week, over half had a split.
www.classicretrofit.com
Old 05-31-2016, 03:57 PM
ROW '78 911 Targa
timmy2's Avatar
No shield for minor operational testing is ok. You need the shields long term as they not only shield the signals from emf etc. they also provide a ground path for the CDI box.
Dennis
Old 05-31-2016, 04:08 PM
