Dooodahman's Avatar
G50 Guide Tube
How can I tell if my TOB/guide tube were updated? (My cross shaft has the factory update, but I know that does not mean the guide tube was done, too.)
Thanks!
Andrew
Andrew
1987 Carrera Cabriolet
1988 Carrera Coupe (RIP)
Gone are the days we stopped to decide where we should go......we just ride.
Old 04-03-2016, 07:13 PM
prschmn's Avatar
guide tube
Tough to tell from the outside. It could have had either-the guide tube update
takes a plastic lined bearing but no way to see it from outside the bell housing.
Mark
www.exotechpower.com
1981 Targa-messed with. 91 C2 supercharged track rat
Radical Prosport-irritates the GT3 guys
40 years of rebuilding services
Old 04-04-2016, 03:22 AM
Dooodahman's Avatar
I should have mentioned, I've got the engine out and separated from the tranny! So I can see the bearing and guide tube, I just don't know what to look for.
Andrew
Old 04-04-2016, 05:47 AM
prschmn's Avatar
newer T/O bearings have a plastic sleeve that rides on the updated tube
Mark
Old 04-04-2016, 06:30 AM
Hi Andrew. Here is a pic of the TOB that came in the Sachs G50 clutch kit I got. I had to update my guide tube for this TOB because my existing on would not fit.
Old 04-04-2016, 09:59 AM
Dooodahman's Avatar
Hmmmm....looks like I have the old one, but I may need to clean off the front to be sure.
Andrew
Old 04-04-2016, 10:03 AM
KTL KTL is online now
Schleprock
KTL's Avatar
You can measure it since you have the trans separated from the engine
http://forums.pelicanparts.com/porsche-911-technical-forum/840048-g50-actual-recall.html#post8368344
Kevin L
'86 Carrera "Larry"
Old 04-04-2016, 12:49 PM
Dooodahman's Avatar
Thanks!
Andrew
Old 04-04-2016, 12:52 PM
Schleprock
KTL's Avatar
Yup no problem.
Also you can get an idea of how old you clutch is by the date on it. In your picture there are numbers on the clutch spring fingers from 12 o'clock to approx. 2 o'clock. The last numbers are typically the year of manufacture if I recall correctly.
Kevin L
'86 Carrera "Larry"
Old 04-04-2016, 01:34 PM
Dooodahman's Avatar
Originally Posted by ktl View Post
... The last numbers are typically the year of manufacture if i recall correctly.
"89"!!!
And I measured and confirmed I have the old bearing. Might as well replace them I guess. Man this is getting expensive!!!!
Old 04-04-2016, 03:30 PM
