911 SC oil smoke under load
At idle the car doesn't smoke, under load it smokes heavily and is burning oil so badly I parked it. What suggestions do you have on Cause?
PCA Member since 1988
How many miles? Does it smoke more on deceleration in gear, than on acceleration?
Typical on these cars with higher miles is worn valve guides and seals. Do a leakdown test.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
The leakdown test is designed to give you those answers. The rest is an educated guess. Most likely rings or guides, or both. Only way to determine prior to tear down is Leakdown. Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
