QSC Cylinders
What is the consensus on QSC cylinders these days? I have alusil on my 3.0 engine and was originally considering re-ringing although have changed my mind. Of course the "while you're in there" bug has kicked in and now I'm considering additional displacement. However there is a budget to be considered.
I saw these which are only slightly more than having my cylinders replated. Porsche 911 98mm Aluminum Nikasil Coated Cylinders Set – QSCUSA Has anyone used them. I'm also assuming I can use these on my 3.0. If not I will just replate my cylinders and keep everything at 95mm.
Matt. 83 911SC 85.5 944 NA - Sold |
(man/dude)
The same website shows the cylinders and pistons for $2258.00. Your SC has different size wrist pins than the Carrera (I think? To early to be sure) but you might be able to get them to provide a kit to make your 3.0 a 3.2 Short Stroke.
I have no experience with these parts but hey, parts are parts. Curious to know if anyone has any real, firm, factual, good or bad, info on these. Last edited by Jonny042; 05-28-2016 at 05:07 AM.. |
We had a couple of engines built by Supertec with QSC cylinders several years ago. We didn't have any problems and they were good engines. That said, I believe Henry did a lot of QA inspection and rejected any discrepant parts. So buying a set direct from QSC might not be the same. You might consider having your cylinders bored out and plated by EBS and getting JE pistons for a 3.2 short stroke.
I enquired with Henry about QSC cylinders not so long ago, he wouldn't recommend them these days.
Yeah, I think you're right. I was thinking of the 3.2. Depending on your engine specs you might be able to get some power from higher compression pistons, like the later euro engines have, and some cams.
Under the radar
The 3,0 SC cylinders can and are bored for 98mm. Some will point out that the thin lip left at the top of the cylinder can be a weak point.
