low speed drivability (like creeping in traffic).
I suspect this is just the way these cars ('86 3.2, 75k miles) are, but I'm wondering if there's a way to improve things.
If I'm in first gear, as in a line of cars creeping up to a stop sign or light, and roll on and off the gas, the car bucks something fierce. The only way to drive it smoothly in these cases is to push the clutch in. This coupled with the fact that my first gear synchros are useless makes life difficult. The car also shows the behavior in 2nd gear though it's not as bad and not really an issue. By contrast, my new daily driver can literally be driven in first gear, with the clutch out, on idle up a hill with no bucking. I fully realize it's not valid to compare cars made 30 years apart from each other, but any words of wisdom are appreciated. |
My 86 doesn't act like this. I can creep up to lights with no problem. I would start looking at ignition and fuel systems to see what might be amiss.
I've had the car for 5 years or so and in that time, I've replaced the plugs, wires, cap and rotor. The coil is original as far as I know. However, if it is an ignition problem, wouldn't it generally break down either under hard acceleration and/or damp conditions? |
While driving to work this morning, I was thinking about this. I wonder if a sticky ICV could make the engine "hunt"? Also, I know that soft engine and transmission mounts and worn CV joints can amplify bucking or hunting and turn it into a real jerking motion.
I believe it's normal for these 3.2's. My '85 did it and to a lesser extent my '88 does it. On the '85, it was pretty well cured by installing a Steve Wong chip. The idle is set slightly higher if I recall, and I guess the engine management is changed by the chip. Haven't chipped the '88 as it doesn't seem to be as much of a problem as the '85 was although at really slow speeds yeah, it's there...
Interesting - increased bucking at low speed is the only negative from installing a Steve Wong chip on my '88 (and its not that bad)
Mine does have a Steve Wong chip installed by the PO. I guess I could put the original chip back in to see what that does.
Speaking of Steve Wong, any idea if he'll update a previously purchased chip? I've considered doing a cat delete. Also, RedCoupe, as far as the ICV, my car had the problem of the idle bouncing when it's hot. Cleaning the ICV heavily with carb cleaner made this a lot better but didn't seem to do much for the bucking. It does seem like a logical culprit though. |
My car did this and also had a flat spot while cruising. I tackled this using all of the troubleshooting steps outlined in the numerous bucking and hunting threads, including checking the O2 sensor, cleaning and checking the ICV, checking for vacuum leaks, re-setting base idle, and checking/adjusting the track/wiper on the AFM. In my case I smoothed it all out when I discovered that a previous wrench had molested the AFM, apparently to lean out the air/fuel mix, probably to pass an emissions test:
http://forums.pelicanparts.com/porsche-911-technical-forum/835870-afm-mixture-am-i-lean.html I can now loaf along at idle in first gear with no bucking, and the flat spot is gone. Acceleration from loafing is smooth and linear with no flat spots. Having said that, dealing with stop-and-go traffic driving a car with a manual trans is still no fun. Good luck! GK |
For a car as civilized as a well-sorted 3.2, I think bucking (SW chip or no) is definitely indicative of a minor problem. Pre SW chip and post SW chip, mine never did that--it's a great, smooth "crawler".
I don't know if SW will update a chip for a second owner, but he definitely will (at cost) for an original purchaser of a chip. |
put the original chip back in and then check the AFM.
my brothers had problems like yours and I think that's what fixed his. |
Doesn't sound normal.
My 87 drives smoothly at low speeds. |
It's not that it's not driving smoothly at slow speeds, it just seems like a bit of bucking at times when going slow in heavy traffic & you let up on the pedal. Feels more like slop in the driveline rather than an engine hesitation problem which is why I was surprised the Steve Wong chip had such a good effect on the '85.
My SC has done it, I thought it was considered uncommon but not rare. There has been discussions of the "bucking bronco" syndrome.
One discussion was the "hanging" drivetrain in relationship to the long throttle rod and/or clutch cable, that you can get a frequency where the drivetrain is actually shaking the rod, which makes the throttle flutter, which makes the drivetrain shake, which is a vicious cycle. |
My SC does it a little too. I just think of it as the car telling me it's not a commuter car, but a car that dreams of wide open spaces (and wide open throttle).
Plus first gear is far too high for crawling along in traffic. Too much riding the clutch and stop and start - Corolla time I call it. |
It bucks because the timing is too advanced. A Steve Wong chip should fix this. I can dial this in easily with my aftermarket EMS MegaSquirt.
Too much timing, buck city. Retard a few degrees, smooth running. It's been called the "neighborhood creep". |
My 83 build 3.2 also does this. I was going to have it set up to see if there are any problems.
I fixed mine by reverting to the stock chip. Much improved low speed driveability.
Mine does it a bit (very mild) at really slow speeds, right before you feel like your about to stall. Honestly, I just avoid going that slow... :P
Your throttle position sensor has two switches in it, one for idle, and one for Wide Open Throttle.
You want that adjusted so that the idle switch is only activated at idle. Once you crack the throttle open, you want that switch off, so the engine can make its own determination of what is happening via the other sensors. |
Would what you say still apply in that case? |
Mine was horrible when trolling through a parking lot at idle. Once I replaced the cracked vacuum lines, the bucking was history even with a 9i3 Octane SW Chip.
I have the same car with a SW chip.
Mine behaved like yours until I recently adjusted the idle mixture. Apparently it was too rich |
Beauty of 3D ignition mapping! |
If it were my car, I would get into the the AFM and fatten up the mixture. |
Seems abnormal for the RPM range you describe. My 3.2 (stock euro) is OK around town in heavy traffic....the cable clutch is not as refined as a modern car however. My 993 has a light weight flywheel and clutch though, and in certain circumstances it pulses and lightly bucks at low RPM. You have a stock flywheel do you? Cheers
Worn tracks on the AFM wiper surface will cause this exact condition. It's fairly easy to modify how the wiper arm sweeps across the track and move it slightly to a fresh spot.
Does it go away when the engine is warm?
Does it buck in second gear as well, or only first? (Mine occasionally bucks between 2-2.5K, but always goes away when the temp gauge needle comes off its peg.) |
I would look for a vacuum leak first. "Bucking" is usually an indication of a lean condition or not enough ignition advance. Typically, the leaner the AFR, the more ignition advance you want (to a degree - no pun intended). Since these engines are distributed and if your base ignition timing is set correctly, most certainly the problem is a lean condition caused by vacuum leaks.
I'm not well versed on the AFM in these motronic systems, but as others have said, you may have a dead wiper spot at that particular air flow. |
I don't understand the situation.
Can you post a video dash cam? In my '86, I can drive slowly with no bucking. It's a hassle, just as in any manual car. Once you are going too slowly, you need to push the clutch in. That's just how clutches work. When I let off the clutch, it engages, and rolls, but does not buck. My car is identical to any other stick shift car in traffic. |
Judicious use of the clutch controls my low speed bucking. Not to be confused with bucking at speed or when under acceleration. Honestly, I think it's just the characteristic of a car that is meant to be driven at higher speeds rather than trolling around a parking lot.
The car doesn't start "bucking" at over 1000 RPM unless something is wrong. The joy of electronic engine management systems is they can compensate for so many issues that you often can't tell that something is wrong until it is really wrong.
Plus when you add to this the truth that full throttle operation is so basic that you can have damn near everything wrong and it will still run right with the pedal mashed. This means that you can convince yourself there isn't an issue. Problems that can cause this are kind of a list of a major portion of the management system. Big things I would check are: - Vacuum leaks. Every chunk of rubber in the engine compartment is suspect and you either need to use smoke, pressure, visual inspection, or a combination of all of them. Plus the intake gaskets are a common failure. (I was surprised to find that the main breather hose isn't supposed to be hard but was actually extremely soft and pliable! All the rubber is probably toast.) - The ICV is a failure point and there are plenty of threads on cleaning them or diagnosing them. - The mixture is often out of adjustment because with the self-correcting nature of the DME you just can't tell. Go through the adjustment procedure. - The Air Flow Meter has a "wiper track" that is a wear item that can cause issues especially in the air flow ranges where the engine has seen the most use. There are good How-Tos on checking and correcting these issues. - Because it is all electronic, wiring is extremely important. Check your grounds (especially on the driver's side intake manifold) and check that the engine harness. Also check that the injector harness's connection at the front of the engine compartment is firm. - If there is a lot of flex in the drive system this can cause some limited bucking just because it has a bouncing oscillation and that can even make your foot oscillate/bounce on the gas pedal. With the car off and in 1st gear look at the engine as you rock the car forward and aft hard to see if the engine is moving. |
I can take my 930 down to slow speeds, and that is with a 1st gear that I can do 60mph in. now if you are trying to drive it at 800rpm that's different. |
A G50, 915, or 901 would easily buck due to super low gear ratios. Drive a heavy duty truck, and they buck like crazy in lower gears. |
I'd vote for checking the AFM also.
Does the idle hunt for a minute at cold startup also? |
Also, thanks Quicksilver. Great list. |
It might be out of whack due to injectors flowing different amounts
| All times are GMT -8. The time now is 10:14 AM. |
