Bad brake piston
Hi All, I have removed the pistons from my front calipers of my 71 911T.
One of them was a bit damaged. See photos.
1) Should I get a new one or is this damage "on the right side" of the seal?
2) If I should replace it, can I get OE pistons somewhere?
3) If I replace, do I have to replace both in the same caliper?
Thanks for any input!
Jörgen Forssling
Göteborg
SWEDEN
Old 08-21-2016, 09:07 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Contact Bigg Reds in the U.K. if you race your car, contact Chris Seven here, he make Titanium pistons, also in U.K.
I just ordered rears from Bigg Reds, they are NLA here in the states.
'85 Carrera Targa
PCA/POC
Old 08-21-2016, 09:36 AM
Thanks for your reply!
I guess this means I should replace the piston? Just the damaged one or both? Or all four in front?
//Jörgen
Old 08-21-2016, 10:02 PM
Replace ! I just ordered new ones from Bigg Red in the UK myself. Even if your old piston should work after assembly it will cause trouble
80SC (ex California)
Old 08-21-2016, 10:14 PM
Replace the one or all?
//Jörgen
Old 08-21-2016, 10:18 PM
Bigg Red
you will need to call them or e-mail them to find the correct part numbers
Old 08-21-2016, 10:41 PM
I mailed them already! But what do you think about replacing all or just the one?
//Jörgen
Old 08-21-2016, 10:42 PM
Discseven's Avatar
Jorgen... replacing all serves to maintain "balance" in the system. In other words, it is possible for a new part to behave differently than an old part. While that's acceptable in certain areas, it's undesirable where performance braking is concerned.
(If pistons are not looking good, what do cylinders look like?)
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 08-21-2016, 10:46 PM
Thanks!
I'm looking for a used piston to replace the damaged one. If I can't find one, I will replace all of them in the front.
The cylinders looks perfect actually. I think this damaged piston was put in by PO back when these cars were not so appreciated as now.
//Jörgen
Old 08-21-2016, 10:50 PM
DRACO A5OG's Avatar
YES, replace all four pistons.
But if you are on a limited budget, then I understand, you have to do what you have to do.
Yeah, don't post the pics of your calipers here, others will or may not consider it perfect because if the PO gouged the piston/s like that and put them back in like that the walls could be damaged of the caliper/s. Just my 2 cents.
Good Luck with your repair.
'85 Carrera Targa
PCA/POC
Old 08-22-2016, 02:34 AM
I will check the calipers thoroughly once I split them. Even though I'm on a budget I won't put in bad parts regarding the brakes.
//Jörgen
Old 08-22-2016, 02:51 AM
DRACO A5OG's Avatar
Split? Sure you want to do that? Gosh, if you don't have to, I would not recommend that, some have issues sealing the caliper after a split.
Just make certain you can not feel any imperfections on the piston receiver walls. As far as the seal grove, I used an angle fitting for my dremel tool and used a the plastic wire wheel to clean the grove out before installing a new seal. Do not use a metal cleaning tool on the walls.
Good Luck Brother
'85 Carrera Targa
PCA/POC
Old 08-22-2016, 03:24 AM
Good Luck Brother
Thanks! I guess I need that. I'm going to replate the calipers and bolts so there is no other way than full disassembly.
Learning by doing...
//Jörgen
Old 08-22-2016, 03:30 AM
DRACO A5OG's Avatar
I hear you Brother , well, POSITIVE thoughts for you and keep us posted on your progress.
Jim
'85 Carrera Targa
PCA/POC
Old 08-22-2016, 03:38 AM
I will! Cheers!
//Jörgen
Old 08-22-2016, 03:42 AM
always replace pistons, calipers,or brake pads in pairs as a minimum and by the way that piston is way beyond saving even for a paper weight.
Lorne M.
83 SC
Old 08-22-2016, 03:19 PM
DRACO A5OG's Avatar
LOL, I use my old one to keep the lid on the grease jar closed
'85 Carrera Targa
PCA/POC
Old 08-22-2016, 05:41 PM
Lorne M.
Thats what I wanted to know.
Thanks!
//J
Old 08-22-2016, 09:22 PM
Send a message via Skype™ to Porboynz
When you get them re-plated, I suggest you bolt the calipers back together with standard bolts to prevent the machined surfaces plating and also it prevent mix ups. You do not want to plate the original bolts. Make sure you source the correct Ribe socket to hold the head while torqueing up the nut and be very sure of your torque wrench accuracy, I suggest a 3/8 or even 1/4 inch drive torque wrench. I sourced replacement O rings from Mercedes, same part used in a Mercedes Unimog caliper, who knew? That piston is not re-useable, if the others are the same then replace all of them. By the time you strip, re-plate, new pistons and seals and re-assemble you should compare cost with aftermarket reproduction calipers. I did exactly what you are planning to do and now regret not sourcing PMB refurbished units. The plating finish ended up incorrect and many other hassles. I appreciate that sending cores to PMB and freight back is a killer from Sweden but take a look at the calipers from design911.com
One other tip is a local brake shop was able to rebuild my pistons with a stainless steel sleeve, but they were in better shape than the photo you posted, looks like they have been attacked with vice grips or worse. Good luck.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 08-22-2016, 10:20 PM
Lots of good advice there, thanks a bunch!
I have the right Ribe bits. And will follow your advice regarding plating the caliper assembled with other bolts.
The other pistons are fine, thats why I'm hesitating on putting in new. And the cost is what it is in this hobby. But I enjoy doing things myself and learning. There are firms here in Sweden that could do the caliper too.
Cheers,
Jörgen
Old 08-23-2016, 12:06 AM
