1st batch of parts back from zinc plating
I pulled the engine and transmission from my 84 Targa and am doing a major refresh. I just got the first batch of parts back from plating for the intake.
I used a fine wire wheel brush on a bench grinder to clean everything up before I sent them out. I spent several hours on the wire wheel and it helped everything come out great: ![]()
Nice EM.
Are you inclined to share details.. Who did the plating, cost, time frame, problems if any? .
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
very nice-i just hope you had the fuel rails blocked
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
I need to do this, looks great.
72 911 Although it is done at the moment, it will never be finished. |
The 9 Store
I do the same wire wheel on a bench grinder prep. I’ve tried lots of other methods but the wire wheel is good for 98% of the prep.
All used parts sold as is. |
I used Cadillac Plating in Orange, CA.
I think it was $60 for the batch and took about 3 days. No issues and the parts came out great! https://www.yelp.com/biz/cadillac-plating-co-orange |
Had a batch done in SFV, zero prep, came out amazing. Not worth the time to wheel everything imo. Infact I had sand blasted one of the brackets before, and could not tell them apart when I got them back.
DIY wrencher
Always satisfying to get back nasty old hardware from plating!
I agree however, probably not necessary to spend time wire wheeling anything. I dropped off all the metal hardware from an entire car, exactly as it came off, rusty and all as you see it below, and it all came out great. They do one or two acid baths before the zinc plating, so any surface finish or corrosion gets removed automatically. 1 by lukas.matzinger, on Flickr 2 by lukas.matzinger, on Flickr 3 by lukas.matzinger, on Flickr
88 911 Carrera 3.2 G50 - driver 77 911S - rust bucket backdate project IG: @lukas.matzinger |
That looks sooooo nice!
Andy Brian |
Behind the Sun
Local platers charge by the pound.
The more the cheaper it is. The hard work is prepping everything. Degrease, corrosion removal, dents, bends |
The 9 Store
Same with mine. I prep and then it’s about $1/lb.
Senior Member
Any east coast sources?
Chris 1988 911 Carrera Targa (driving project started JAN 2022) 1970 911E - Long since gone 1972 911 Targa - gone 1987 911 Carrera - gone Retired FA-18C Driver |
Lukas, what are the wings for on the grinder? The one on the top left of the three.
DIY wrencher
I added a couple of cheap cordless ones since then, so much more convenient to have them all ready to go with various discs to work anywhere.
its a holding rack for the grinder.
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
DIY wrencher
Ah now I get what he meant!
Yeah those are 2 steel mounts/racks next to each other, that hold 3 (small) grinders each.
Plating
Didn’t see this but I sent a batch to someone but did not understand what fully prepped meant.
Soak in white vinegar and old coating is removed. Careful with magnesium though. Just my 2 cents.
TOT |
Gotcha. I guess I need one or two. Actually have that same grinder on the left which is what piqued my interest.
