4.0 964 motor
Hi,
I need to rebuild my 964 motor and am looking at different options. Is anyone familiar with a 4.0 motor for a 964. I saw Singer is installing them in there cars, but I have not been able to find any other information. Thanks |
They are done by Ed Pink and are not for the faint of wallet.
I am familiar with Ed Pink, but was not thinking of going this route.
I was wondering if anyone else builds them, their reliability and availability of parts. |
Try talking with Jae at Mirage International in San Diego (Miramar to be exact). He builds the 3.8L Singer engines. He is very knowledgeable, pick his brain about a 4.0L.
I've built a couple and other than bragging rights - it's not worth it
SO much machining and clay . . . It's like building three engines. Anyway, even if I had the money for the parts I wouldn't bother building one for myself. Too many limiting factors |
God, that's beautiful. Any body know how much that is? $60-75K?
This looks great too...
http://forums.pelicanparts.com/uploa...1477059228.jpg Call Supertec, they may be able to with their supercrank? |
soooo nice, want to touch the hiney...
Jeff Gamroth at Rothsport or Steve Wiener from Rennsport Systems out of Portland. Those guys are magicians.
Ive been digging into this. Basically a 4.0 is a motor with a bore of 102.7mm ( LN Nickies, I betcha ) and a stroke of 80.4OR it means 104mm bore and 78.4 stroke. This means either a GT3 crankshaft or a custom crankshaft. I am pretty sure you'd also have to use a non-stock oil pump, and you'd have to tweak the rods a bit, and I bet the piston-to-valve clearance will probably require some piston-crown machining.
So, $6K for the pistons and cylinders, $4.5K for the new crank, $1200 for the new oil pump, $1200 for the rods, oh, yeah, gotta twin-plug it to run 11.5:1 compression, so that means EFI and an EMS, which is open-ended but you can spend a LOT of money on that. Then there's induction. You want Velocity stacks or that beautiful big-bore plenum? The options are endless and astronomically priced;) If you just want to boost your displacement, you can swap your pistons an cylinders for a set of Nickies in any size from 100m bore ( stock ) to 106mm, which brings your displacement to a touch over 4.0. Call LN Engineering and see what their tech advisors have to say. They'd be the ones who can say 'for that size, you need twin-plugging', or, 'here's the biggest displacement you can go and still keep the rest of your motor stock'. |
Road & Track lists the bore at 102 mm and the stroke at 80.4 mm for a total of 3940 cc.http://forums.pelicanparts.com/uploa...1477063225.jpg
so anything even close is considered 4.0 then?
Isn't a 964 motor already twin plugged?
Well Singer has a few engine options, could it be that R&T car was a 3.9? If not, a surprising number of tuners and OEMs round up rather generously on engine displacement.
No, it was me in his cups. I was on a roll, what the hell.
If you're really ambitious, there are 82 and even 84mm cranks out there. Go big or go home, right?
| All times are GMT -8. The time now is 08:14 PM. |
