jarrodblake's Avatar
Beautiful! Love the trim ring on the hood I have never seen that done before. Does someone sell them or was it custom made for the build?
Old 07-31-2017, 08:57 PM
I had a design in mind and gave it to a friend of mine who does machining and metal work for cars. He builds custom headers, exhaust, roll bars, roll cages, etc. Also did the rear window straps with the integrated R hinges.
If you need one I can give you his contact number. You can work directly with him
Thanks for the compliments - much appreciated.
08 Aston Martin Vantage V-8 (6 spd manual) (DD)
20 Cayenne white-black/red (hers)
78 930 (heavily modified)
08 GT3 RS (white/black) (modified of course)
67 911S outlaw (sold)
Old 08-01-2017, 05:04 PM
Near completion. Just a few details remain. Should have it wrapped up in a few weeks. Think of adding the PORSCHE side script in gloss black. Already purchased these - just will add these as a final touch.
Thanks again for looking..
Mark
My take on a mix of a modern "R" style drill. 1/4" x 1/4" stainless steel mesh with a 1/4" thick drilled acrylic cover. Mounted using stainless steel standoffs. This enables you to removed the acrylic cover for cleaning without having to remove the entire assembly.
Old 12-04-2017, 10:36 AM
A few more:
The previous owners had the MSD ignition assembly mounted on the rear fire wall. I took the assembly and then designed and fab'd a cover for it with a removable L-shaped face plate. Added the aluminum horizontal bars to tie in with the factory pieces on the dash.
Old 12-04-2017, 10:40 AM
and a bit more:
Old 12-04-2017, 10:41 AM
Steve F's Avatar
Thumbs up
More Wow!!
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate
1967 912-1985 Toyota FJ60 Landcrusier
1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4
1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag
1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS
Old 12-04-2017, 11:02 AM
I am in the process of installing a small aluminum strip to fill in the gap below the kill switches and the fire suppression pull. Painting them to match the larger plate - then of to the laser vendor to have them "engraved" for switch descriptions. The laser will burn thru the paint and leave the aluminum behind. This particular vendor that I use can not cut metal - but it will burn it to etch a design. I am sure the end product will be good. I will post as soon as they are completed
Old 12-05-2017, 09:08 AM
"farking Porsche hero"
Rich Lambert's Avatar
Wow...love the details on this car.
Rich
'66 911 #303872
'07 Cayman
'17 Macan
'58 Land Rover S2 88"
Old 12-06-2017, 08:29 AM
Very very nice - love all the little details
1988 911 Carrera, M491 Cabriolet
2016 Cayenne
Old 12-06-2017, 11:16 AM
I would love to see a picture of the muffler set up, it looks like to separate boxes .
Old 12-06-2017, 03:19 PM
