2 bad injectors. Now what ?
Need your help..I sent my injectors to witchunter and two are not usable. P/n 0280 150 158. They rebuilt 4 of them. What should I do for the two bad ones.replace the two or get all new replacement aftermarket ..what is avaliable in today's world..
Anyone have this happen and what did you do.. |
RETIRED
Well, you buy new ones....$125 from Pelican or try eBay....
Pelican Parts - European Automotive Parts and Accessories - Porsche • BMW • Mercedes • Volkswagen • Audi • Saab • Volvo • MINI
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
What year/model.
I don't think you can rebuild cis injectors only clean them. Id replace them as a set no matter the type be it cis or efi. |
I typed in the p/n search on pelican. It says that they can not guarantee exact fit...and if I look under 1985 911 3.2 the ones that come up are not the same p/n...so confused
RETIRED
Call Pelican and ask for Glenn Sager, he should be able to help......
I had my 3.2 injectors done at Marrin, he sourced me new ones and flow-matched them, tossed the old ones. I eventually ended up with 944 Turbo injectors and a custom dyno tune as they flowed more fuel and that's what the tuner required.
Gary R. |
![]() ![]() These are the results I got back.what do you think? |
I ordered a set of 6 : AIRTEX/WELLS 4G1035 $44 should be here on Wednesday. Anyone else running these. Or does anyone see a problem with them. They have pretty close to stock specs as the Bosch 0280150158.
Another question is Does the Euro spec motor use different injectors then the US cars ? |
Why?
Why did you order 6 new ones when four of them were cleaned and tested to be in good working order ? Some of you guys must have a lot more money than me.
I ordered 6 new because they are not the same brand, aftermarket I didn't want to mix brands not knowing if this would have caused an issue. they were $45 each.
Send them to OKI they will take care of you!! Use them a lot!
OKINJECTORS--Gasoline and Diesel Injector Cleaning, Rebuild, Overhaul, and Testing Services | my-website
AlfasRule! 72 Montreal (Da Pumpkin) 75 Alfetta Sedan, 75 Alfetta Coupe Race Car 82 Spider, 84 GTV-6. 84 GTV-6 Verde (GiGi) 87 Milano ( Da Winta Beata) |
Don't need them rebuilt .already had that done..just wanted to know if euro cars have different injectors due to higher compression.
Irrationally exuberant
3.2 is Motronic, not CIS..
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
The OP did'nt state it was a 3.2 until after I asked what year model.
