gruppe f
mikehinton's Avatar
'87 Carrera no-start
I hopped in the '87 Carrera today for my short commute to work. The car started normally, idled for about 10 seconds, then died. Would not restart. There is plenty of fuel in the tank. Should I start with the fuel pump relay?
TIA
Mike Hinton
'06 Cayman S Carmon Red, '05 Cayenne Turbo Black, '87 Carrera Granite Green, '72 911T Aubergine,
'74 914 1.8 Marathon Blue, '64 356C Aubergine
Old 11-30-2016, 07:58 AM
do you have a spare dme relay? I'd start there
Old 11-30-2016, 08:05 AM
gruppe f
mikehinton's Avatar
I do have one of those, but I can't recall where it plugs in.
Mike Hinton
Old 11-30-2016, 08:16 AM
kuba_kuba's Avatar
Under the driver's seat. If you slide seat all the way back and (if you have height adjustment) all the way up you should be able to identify it.
'88 911 Targa
Old 11-30-2016, 08:30 AM
it's just behind the dme computer
Old 11-30-2016, 08:51 AM
gruppe f
mikehinton's Avatar
Thanks, everyone. I hope I can get to it without removing the seat. That exercise is just too much fun for words!
Mike Hinton
Old 11-30-2016, 09:11 AM
Spiderman
Jesse16's Avatar
Just unplug from the current and plug in the replacement, don't bother unbolting the questionable unit to start. Its attached by a single bolt to the floor, you'll see on the "new one. Can go back and forth as you troubleshoot.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 11-30-2016, 09:16 AM
gruppe f
mikehinton's Avatar
Thank you again to all who responded. Replaced the DME relay (I did have to remove the seat), and all is well again. This community is the BEST!
Mike Hinton
Old 11-30-2016, 03:48 PM
Go buy a loto ticket
crude rudy
'84 cab
'14 ZX-14R
Old 11-30-2016, 04:11 PM
RETIRED
Joe Bob's Avatar
Buy another spare. Consider the solid state one they sell on eBay....
2012 ML350 3.0 Turbo Diesel
Old 11-30-2016, 04:31 PM
Is this fuel pump relay prone to failure?
If so, I'll buy one off ebay as a spare 'just in case'
1987 Porsche 911 Carrera Coupe
Old 11-30-2016, 07:01 PM
Those bosch fuel pumps are pretty robust and easy to find. I'd consider replacing it only if you start to hear funny noises coming out of it. They'll usually do some complaining before just dropping dead. Some people like to do a voltage drop test as an advance warning to check the condition of their pump.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 12-01-2016, 03:44 AM
gruppe f
mikehinton's Avatar
I will definitely be buying a replacement DME relay to carry in the car. I also do carry a fuel pump relay, but have never had to replace it in the 9 years that I've owned the car.
Mike Hinton
Old 12-01-2016, 08:56 AM
If you're really anxious to change something out that may go bad, then check your speed & reference sensor wires. The insulation was crumbling off them in my '88 so I replaced them and the cylinder head temperature sensor this past summer.
You can see the condition of those wires by looking in the driver's side of the engine bay. If they fail, you'll get the same no start condition.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 12-01-2016, 09:09 AM
gruppe f
mikehinton's Avatar
Thanks for the tip. I'll check those wires out, and replace if necessary.
Mike Hinton
Old 12-01-2016, 01:11 PM
Diss Member
Quicksilver's Avatar
The insulation was crumbling off mine over a 75K miles ago. Still running perfect. I guess I will do something about them when I get the 3.5 done.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 12-02-2016, 05:44 AM
Yeah, that thick black insulation is the outermost layer. Underneath, there's another silver layer still protecting the wires. I wasn't so much worried about the insulation causing a short as the age of the sensors was probably going to give me a no start eventually. When they go, you're really stuck...
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 12-02-2016, 06:21 AM
