Author of "101 Projects"
Wayne 962's Avatar
Recommendations for an oscilliscope?
While testing the mag pickups on the green RSR tonight, our 50+ year old oscilliscope died. I went on eBay, and there are hundreds in the $50-$100 price range - anyone have any suggestions?
thx,
Wayne
Old 01-05-2017, 04:49 AM
I would not do the $50-$100 ones. They are less than toys and not for serious work. If you are going to do anything serious, at least spend the $400 for a decent one from China. Rigol makes some good ones.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 01-05-2017, 06:54 AM
Hi, I've also been looking at these for a while, and am personally leaning towards getting a used one from a reputable company like tektronics. We have these in the lab at work for decades, and they practically never die.
like this one: eBay item number:252690254687
___oOo___
1972 S 911 Targa kit
http://forums.pelicanparts.com/porsche-911-technical-forum/863768-thats-my-first-911-restoration-thread-72-911-s-back-grave-maybe.html
Old 01-05-2017, 07:25 AM
Irrationally exuberant
ChrisBennet's Avatar
I really liked my old Fluke scopemeter 190 series for working on cars.
Every time I loaned it out it came back broken and the last time I decided to get a $400 Rigol.
Maybe I'm stuck in my ways but it is not as nearly as easy to use as the Fluke.
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 01-05-2017, 08:31 AM
In my opinion, the best scope to get if basic scope functions are required, ( no special automotive features) look at Pico. Excellent piece and connects to your laptop for display. Record as long as your lap top has power, stop, rewind, expand, overlays, etc, often features unavailable in the lower cost standalone scopes. They offer single, dual and multi channels versions. I think a dual trace version is in the $ 400.00 range. Approx 6" square and 1' thick. Simple and very user friendly.
Old 01-05-2017, 08:36 AM
T77911S's Avatar
post some links to the ones you are interested in.
I am an electronics tech for the FAA
we have the tektronics 2246.
I prefer analog Oscopes for most things. its kind of like a digital TV trying to display fog, you don't get smooth transitions from the shades of darkness or light. that's how digital scopes are for some signals.
I liked the digital scopes for adjusting square pulses on this old equipment we use to have. for the pilots out there it was our beacon interrogator system. it used tubes.
the digital scope could measure pluse width, rise time and fall time and display it all while adjusting the pulse. that way I did not have to stop and measure those things.
we now have a digital radar system that came with digital scopes but I prefer the analog scope.
I have a digital at home only because it was free. I have only used it to look at the signal out of the distributor of my 930. it was fine for that.
oh, the calibration van will be here in a week or so, if you post something they may know if it is good.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 01-05-2017, 09:17 AM
db_cooper's Avatar
thx,
Wayne
Wayne..while you are waiting for your oscilloscope..many years ago in a galaxy far away..I made a quick tester for DME components and the like. Crank or cam senders, injectors and so forth.
Using a red LED and a 220ohm .5 watt resistor wired in. some of the small male blades and insulated with tape and enclosed in a length of fuel line.
I disassembled my tester after 30 years to confirm the value of the resistor reccomendation..it needs to cleaned up too.
Works well..is polarity sensitive as we all know with the LED. No problem if installed backwards for testing. Nice bright flash when it gets a pulse..no flash..no pulse..easy.
Should work on your mag pickups..just for testing.
A picture of the disassembly tester..
Old 01-05-2017, 09:20 AM
Seen a few of these around guys that are into electronics repair.
https://www.amazon.com/Rigol-DS1102E-100MHz-Digital-Oscilloscope/dp/B001VKCJ0M/ref=sr_1_1?ie=UTF8&qid=1476236584&sr=8-1&keywords=rigol+ds1102e
Not cheap but not crazy expensive.
Old 01-06-2017, 11:00 PM
I would rather be driving
jpnovak's Avatar
I have a handlheld Velleman scope meter. I use it all the time for car stuff. I have had it for about 8 years. It was inexpensive and easy to use. I did not have the budget for a Fluke at the time.
Old 01-07-2017, 04:04 AM
I am not current in technology there may have been advances in the last 20 years I am unaware of.
I have an old Tektronix 4 channel analog scope and an old Tektronix 2 channel digital handheld scope. I like both, the analog for slower speed things I don't need to store or capture. The digital for faster things I need to trigger off and capture for review. Having a current probe attachment with my handheld digital has been valuable over the years.
I would think you probably need something like 100MHZ in a digital storage scope.
72 Porsche 911T/E Targa
72 Porsche 911S
85 BMW 735i
Old 01-07-2017, 04:07 AM
Diss Member
Quicksilver's Avatar
I found my scope on Craigslist for cheap. 2 channel digital storage with a couple probes for $100.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 01-07-2017, 06:16 AM
Always Be Fixing Cars
Sorry to semi-jack here but can someone explain a few of the automotive things one would use a scope for as opposed a multimeter?
'91 964 C4 - New Daily
'73 Alfa GTV - 90% done 50% to go
'65 912 - Welding in process
Old 01-07-2017, 07:37 AM
wrxnofx's Avatar
Certain things on all cars produce a wave form (speed and reference sensors, for example), whether square wave or sine wave. A multimeter can't "read" this wave. An oscilloscope enables you to view this wave form and see if it is correct, if there are drop outs, etc.
I'd look at a Pico if I was looking for an oscilloscope. Connects to your laptop, completely configurable.
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 01-07-2017, 08:20 AM
Ignition, injectors, O2 sensors, TDC sensor.... You know, the analog stuff.
Old 01-07-2017, 09:18 AM
I have a rigol ds1052e and have been very happy with it.
Some of the things you can check with a scope are :
Injector wave forms/ flyback voltage
Primary and secondary ignition waveforms.
Pwm duty cycle and frequency
Fuel pump armature condition.
Relays ( such as relay bounce or fluttering)
Voltage.....
Current (need current clamp)
And lots more of fun things....?
Old 01-07-2017, 09:44 AM
steely's Avatar
I used Tektronix and LeCroy in work but they were all high-end. The newer DSO's were becoming smaller/almost pad-like. You won't need really high speed/bandwidth. Get something for the bench and the floor.
I bought a cheapie nano because I use it only once a year. Helped me diagnose a bad ICV driver on the DME, but you should get a real one.
on edit: my pic isn't coming up right away as I write this
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 01-07-2017, 01:10 PM
Scope it out
I recently bought an Owon 4 channel touch screen to replace my 20 year old Hitachi. The Chinese stuff has come a long way. I came from an environment that was all Tektronix and HP. Read the reviews.... I also have a Tektronix 214 that has an internal battery so you can help other brands when dead on the side O' the road...
Old 01-07-2017, 02:09 PM
Wayne
I like the Hantek 1008c that is a USB SCOPE that plugs into the USB port on a laptop of computer. This model has many auto functions built in and has signal generator as well.
It has been great to trouble shoot early 911 ignitions and electrical.
I have also used in on other care auto electronics trouble shooting.
At less than $100 USD they are very good value for the money.
Here is an eBay listing
Hantek 1008c Oscilloscope 8CH USB Automotive Diagnostic DAQ Generator NM N15T | eBay
and here is an Amazon one.
https://www.amazon.com/Hantek-Automotive-Diagnostic-Oscilloscope-Programmable/dp/B00BSR98KW/ref=sr_1_1?ie=UTF8&qid=1483833270&sr=8-1&keywords=hantek+1008c
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 01-07-2017, 03:56 PM
03 Boxster
Old 01-07-2017, 04:03 PM
I'll second the Pico scopes, very good!
Old 01-07-2017, 06:17 PM
