Unconstitutional Patriot
I am still undecided. I like the MA Shaw reputation. It also sounds like the BW Motorsports is a good selection. I probably would not take advantage of the 'nerf' bars, since my Euro model does not have bumper shocks. I would like to see some pictures of the bars, so I can determine if they really do provide crash protection above 1 mph. It takes a lot of strength to withstand the momentum of a car(not implying the BW nerf bars aren't up to the task).
If price were my sole motivator, then the Rennspeed pieces would be on my car. I guess it comes down to whose product I trust the most. Ok, who's next...? I'm finished with the mic. Jurgen |
I bought Shaw from reputation and feed back of the guys installing them in our area. I also liked what Mike had to say when I called. Mine have been shipped. I'll try to detail the process from unpacking to the paint and detail work over the next few weeks.
Money wasn't a real object on the choice......compared to what they cost to paint and install, 500 to 600 bucks either way isn't gonna mean a lot in the end I suspect. We own Porsches for crimney sake! Hard to justify the Rup parts when there are other extremely high quality sets available. But some where between $1000 and $3000 for parts should cover a decent set of bumpers I am really curious as to what everyone pays for the install and paint....again done at a "excellence is expected" level.
turbo6bar,
the eurocars are a better choice than the US for the nerf bars because they use the non-hydraulic shocks to mount to the chassis. The front and rears shocks swap positions and one of them(can not remember which is shortened a bit w/ a torch). Unfortunately I can't provide pics becaus it was done so long ago. The BW Nerf bars are just properly shaped iron that bolts to the oem shock pads. They just sit behind the bumper caps. The nerf bars just provide a bit more crush zone. They do not replace the function of the oem bumpers. The front nerf bar is a great place to hang an oil cooler from. They can easily be fabbed from aluminum for more weight savings. The bumper strut/shock is a simple assembly ![]() The BW pieces are very nice, light, finished nicely and look factory installed. They are also tough.
thanks for the post Bill, looked at your pictures, they do look stock, such a nice fit to them...right now I'm leaning towards the BWM's but will also consider the MA SHAW ones for group buy...
1992 964 C4 Coupe (black/black) 1982 911SC Coupe (lt blue met/black) 1965 Mustang Fastback (black/black) |
rdane, at this point price is not really important. However, as I said before, if price was king, Rennspeed parts would be the ones to purchase. I'm leaning towards the MA Shaw & BW Motorsports pieces. As far as installation costs, I'm doing all the work and painting, so it won't be an expensive project. I really love the SC, so I'm not cutting any corners.
Contrary to popular belief, I don't feel ownership requires lots of money to enjoy the Porsche experience. However, an open wallet sure helps. ![]() I'll probably fabricate my own bumper bars from square mild steel tubing. It's easy to work, and the square shape allows fasteners to be installed easily. Aluminum angle would be a trick light alternative.... Souk, you've been diplomatic so far. How about an opinion? ![]() Jurgen |
I'm leaning towards the BW pieces since I know my Ruf rubber lip will attach since that is what Bill Verburg has installed.
Todd
1989 911 Targa |
is the yellow car sc flared or ruf flared?
tholyoak, remember that the lip is NLA from Ruf. It would be easy to fabricate once suitable rubber in found.
Here you can see the bumper/nerf bar mount and the end of the nerf bar itself, it's just angle iron This is where large wheel and tire packages will have the most interference
Bill
I already own the rubber lip from Ruf, so obtaining one is not a problem. It is a simple piece that would indeed be easy to replicate Todd
1989 911 Targa |
The bumper caps are only going to be as good as the molds. It would be nice to know who used a real RUF cap and used one of there competeters. I personaly think being that none of the companies have them in stock and are going to have to make them they will be extra careful. A bad bumper in this group buy could be diasterous to their reputation. With that said I could always save an extra buck, I am leaning towards Rennspeed.
The unique thing about the RUF rubber lip is it's material. The best way to describe it would be that it's like a tire w/o tread. It actually is multible ply's of rubber and chord. It is very stiff and durable. I was able to round up one more lip for our fearless leader but he has decided to come up with his own sooo... Original RUF lip for YB $200.00. www.piedogger@aol.com
Euro 83 cab. SC |
It looks like the RUF lip spoiler must/should be used in concert with a tail. I don't plan to run a tail. Doesn't sound like a mismatch with the RUF bumpers, eh? I would love to grab a 964 tail, but the previous owner just spent $$$ getting the A/C redone, along with a new decklid mounted condenser and custom lines. I'd hate to dump all the labor and parts just to go with the 964 decklid. Maybe later.
Also, in case anyone was wondering about the license plate lights on Bill's car, they're from a junkyard Japanese vehicle (honda/toyota). I like it a LOT. Jurgen |
The lip can easily be fabbed from flat conveyer belt type material. If you do this then you can make the lip as deep as you like, keeping in mind that the deeper it is the stiffer it will need to be. The difficulty will be in forming the radiused ends neatly.
The l/p lights came for a Japanese econobox Nissan/Toyota? in a junk yard. I painted them to match the rest of the trim. An other more expensive alternative is BMW 2002 l/p lights. I personally don't like them beacause of their exposed bolts.
Bill, great pictures, thanks! That sure will help when I am talking to Mark while he is doing the install.
"Contrary to popular belief, I don't feel ownership requires lots of money to enjoy the Porsche experience. However, an open wallet sure helps." No question Jurgen, if money were no object we would all be driving the real Ruf cars Now that would be a group looking for world domination :lol:I work with my hands everyday and advise people on how to spend several $s at a pop of my labor. I learned slowly to take advice from the pros to heart and buy what they recommend in quality and parts. It always saves money and time in the long run. That is a good thing on both ends, buyer and seller. For all I know all the parts mentioned are of equal quality. I was told yesterday that most use molds till they bubble badly while others, Shaw for example, replace the mold every few pieces. I am trying to learn from every post. Bill's photos have really helped as have the conversations with the manufactures and the comments and other pictures here. |
Somewhere in the Midwest
Man, I have tohelp a friend move today so I can't spend time ont his subject, but I promise to later this weekend and send out more info.
Pie, I'm one of those 911 owners with a tight parts budget so I can't afford the bumpers and the Ruf lip this month, but if you can hold on to the part for another month to 2 month, I promise to buy it from you (now that it's public, I'm commited). Bill V, thank you so much for the posting! More later. Thanks for the input guys. |
Souk,
I did not mean to imply anything, When I sold the last one I was told no more no matter what! RUF does not want people with aftermarket bumpers getting them. So I advertisied it that way (last one) you e-mailed me at almost the exact time the person that bought it did and as I said "I would see what I could" My friend was able to pull a favor and get it. I just don't want to be telling people it's the last one and then after they buy it advertise another one as last one. If you want it I will save it if not no problem just let me know. RUF has these, the only reason they are NLA is because they don't want them to be used aftermarket. You have to remember they spent all the money on design and development, building molds from scratch ect... These after market people just have to buy one and use it to make a mold. I would be willing to bet other than the first one (who ever that was?) everyone else has used an aftermarket one as there mold. The farther from the original you are the more fit problems COULD happen. I am not doubting MA SHAW as I am not a fiberglass expert but when ever I make a mold it takes a few weeks, every thing must dry longer so it is extra hard. You also have to put multible layers of wax in it which has to dry between coats so the plug will not stick to the mold. So unless there is a secret in the industry on making fast molds, a new mold every three pieces it could take quite awhile
Euro 83 cab. SC |
I'll see if I can track down his site address again for ya to go check out. Later! Eric
Famous last words.. "Hold my beer and watch this...' " The reason the Irish are always fightin one another is that there are no other worthy opponents ". |
OK Guys,
You should have an e-mail or a PM regarding the Group Buy. Please reply in e-mail, what ever you decide. Pie, you have a PM to clear up any misunderstanding. Thanks all. AND, there is room for more in the group buy! I think there is more than 20 now!
Guys that will be doing their own mounting and prep, read Pauls' threads on how to mount and paint! (Note: I stand by my vote on the group buy)
Souk, one clarification on your private email I wanted to mention to the others. I don't feel the primed fiberglass is a huge advantage. When I used to do some painting, I was advised to stick with one brand of product. If you start with PPG, you stick with PPG product from etch primer to clearcoat. Unless the seller knows what paint system each person will use, the primer applied might not be ideal. I could be wrong.
However, I do like the fact the company is willing to go the extra two steps. Jurgen |
