Flyin' blind
Originally Posted by redstack View Post
Does your car have the autoheat? Mine does and I still can't figure out how to make it work. Will this mod affect the autoheat system?
My '89 does not have auto-heat. It's basically a base car with only factory tail and valence. I thinks this was unusual in 89.
So, just to be clear, if you have auto-heat, your outcome may be different.
Thom
89 Coupe
Old 03-31-2017, 04:50 PM
Flyin' blind
Finally found some time to complete this. Remove the heater relay and gently pry it open.
Here's a look before the jumper.
And here it is with the jumper in place. As you can see my soldering skills could use some refining....
Reassemble and reinstall, turn the ignition, pull up on the heat levers and Voila!
Thom
89 Coupe
Old 04-04-2017, 01:21 PM
Gunga Galunga
doublebuffle's Avatar
I am trying to do this with my 3.2.
Can someone please explain how one is supposed to modify the heater duct so that it clears the oil lines?
Old 05-01-2017, 09:37 AM
With a hammer and/or pliers.
Old 05-01-2017, 10:01 AM
Flojo's Avatar
Originally Posted by BFT3.2 View Post
I did the same heat back-date in my 3.2, ...
I'm a detail-person. this makes me fringe...
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 05-01-2017, 11:58 AM
Flyin' blind
The duct sat right on top of the line in my car, no mods needed. There may be some variation in the manufacture of the duct. I think you could "massage" the duct with a ball-peen hammer .
Thom
89 Coupe
Old 05-01-2017, 12:23 PM
Gunga Galunga
I could do some "massaging" but that duct outlet would have to end up about a 1/4" higher... and I don't think that technique will get me there.
I'm bringing it into work for a second opinion, but im thinking this may be a cut and weld situation in my case.
Old 05-02-2017, 07:36 AM
/ˈpɔrʃə/ PORSH-ə Fan
LUFTKUL's Avatar
Unlikely that the duct is off. The problem is the height of the carrera tensioner oil lines, specifically at the "T" joint. I had an '88 and an '84 at my house recently and was able to compare. The '88 line would barely allow a quarter to slide between the line "T" and the case. The '84 I could stick my finger between the line "T" and the case and still move up and down. It's the way the oil line is run. You can either "persuade" the oil line down or modify the duct or a little of both.
1984 ROW Carrera Sunroof Coupe Schieferblau
1982 US SC Targa Moosgrun
1977 US 911S Sunroof Coupe - SOLD
Old 05-02-2017, 07:42 AM
I massaged both the duct and the oil lines. The duct ended up with a flat profile on the bottom.
Old 05-02-2017, 05:23 PM
That bolt on the left looks like the receiver for the carbon fiber rod setup. The rod sits in the depression of the cap head.
Old 05-02-2017, 05:26 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Originally Posted by Lake Guy View Post
... Good write up Thom. I'm curious about how much heat still gets to the passenger compartment with the main blower removed...
L.G.
Not sure if it was answered. With a 3.2 you will get plenty of heat. I drive my Cab with the top down in single digit temperature with no problem.
Who Will Live... Will See
Old 05-02-2017, 05:30 PM
JJ 911SC's Avatar
All the CAT I look at has the same bolt on either side and it's not a Hex head.
Old 05-02-2017, 05:33 PM
douglas bray's Avatar
I switch out the autoheat in favor of manual pulls. Driver's side pull sends heat to the windscreen and the passenger side pull sends it to the passenger's feet. No blowers in the heat system at all other than the engine fan. Works fantastic.
Old 05-02-2017, 05:34 PM
My 1985 has motor mount bolts that are all hex head. Do you mean the socket cap head screw on the left?
To me it looks like part of a kit to remove the rear deck lid strut with a single carbon fiber rod:
Ult-Strut,TopDetail
I have such an item, but have yet to install it, and that is why it caught my eye.
Old 05-02-2017, 07:30 PM
Flojo's Avatar
It's minor, I know..., I just like symmetry ;-)
Old 05-03-2017, 12:41 AM
JJ 911SC's Avatar
Ult-Strut,TopDetail
Yes, I would do like Flojo and put 4 socket cap head screw.
I'm using an older technology...
Old 05-03-2017, 02:30 AM
Flojo's Avatar
sublime engine!
Old 05-03-2017, 02:57 AM
JJ 911SC's Avatar
sublime engine!
Danke
Old 05-03-2017, 05:15 AM
jm993rs's Avatar
Very good !!
Thanks for share !!!
Old 05-03-2017, 06:07 AM
Formerly known as Syzygy
Canada Kev's Avatar
I hear you; I'm the same.
My car has been off the road for a week while I'm trying to source an M5 speed/clip nut for the rear tail light housing mounting screws. One of mine come apart when I removed the lights to replace seals (kinda corroded after being in the fender well for the last thirty years...) and I can't bring myself to replace the screw and nut with an M6 that are readily available. It's not even visible after the lens goes back on. Little bit OCD I guess...
Kevin
Old 05-04-2017, 10:39 PM
