I would NOT consider selling the car, dude! Coulda had the cage out already in the time spent reading this thread :-)
--Dan 1968 911 Coupe 1970 911T Targa 1995 993 Coupe 1997 993 Targa (sold) |
Grappler
Sell the car over a cage??? That's a little dramatic.
Grappler Know Gi / No Gi 1976 RSR Backdate (Turbo 3.2) |
So I removed the front half today in about three hours with help from a friend. I still have to finish grinding down the four mounting locations, reassemble the lower dash, and replace some carpeting.
Overall the job really wasn't that bad. It was tight around the headliner where it attached to the rear hoop but with some patience and a couple of different tools we were able to cut it free without damaging the car at all. The Lenox blades were amazing! They cut right through in about 30 seconds with a sawzall. The grinding will take longer but at least the car is driveable as is. ![]() ![]() ![]() ![]() ![]() ![]()
Good job!!!
Platinum Member
Looks good. If you leave the floor stubs, and with some creative use of PVC adapters & Pipe, you'll have a nice cupholder.....
Just curious, did the fabricator weld the top of the upper bars? (tubes 100% welded around the joint)(one thing that separates the hacks from the pros)
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams Last edited by dad911; 05-21-2017 at 07:25 PM.. |
The top of the of the upper bars were not completed welded. One side was close but the other was not. I don't know how they would've pulled that off with the headliner in place.
