AC compressor nut stuck
When doing a valve adjust, had to move AC compressor out of the way. Unfortunately the nut that sets the AC belt tension got undone all the way, and because of the fan shroud, I can't get it back on the threads. Picture attached? I figure it came off so it should go back on right? But don't want to cross-thread and ruin the stud.
THANKS http://forums.pelicanparts.com/uploa...1494641816.JPG PS: No, I don't want to ditch the AC - I hope to get it operational one day. |
I think you can loosen the shroud strap and pull the fan and shroud forward enough to get the but on...
Steve |
Or cut some of the bolt off.
+1 cut some of the stud off
| All times are GMT -8. The time now is 08:47 PM. |
