'74 oil temp gauge
I'm looking at the wiring to the oil temp / pressure gauge on the dash.
I have green wire that was not connected.
The connections looking at the gauge from the drivers seat with gauge in dash.
Starting from the right at the pressure gauge.
green/red
brown (at bottom middle blade)
red/black (hot wire)
then the temp gauge
no wire to the top middle blade
green/black
The middle blade on both sides is the ground (brown wire) but only one is connected. I assume they both ground to the gauge body so only one is needed?
Should the green wire that is loose in the dash be connected?
Old 05-23-2017, 05:44 PM
HarryD's Avatar
The 1973.5 Wiring Diagram should be the same:
Legend:
Looking at the diagram, it looks like a spare wire.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 05-23-2017, 08:12 PM
ROW '78 911 Targa
timmy2's Avatar
Green is a Spare wire unless you have a sportomatic transmission.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 05-24-2017, 07:04 AM
Thanks.
Spare wire for sportomatic, good to know.
Old 05-24-2017, 07:41 AM
