Slate Grey 6801 in PPG paint
I've been searching the net and these forums, but with no luck:
My friend who does paint and body work uses PPG paints. I haven't been able to find a code or formula he can use for slate grey 6801 in PPG. I'm a rookie when it comes to paint, so any input is appreciated
Old 05-27-2017, 05:43 AM
The Mighty Pieholio
Bob Kontak's Avatar
Just as a side note and I am aware this is not what you are asking. If you are looking for the Steve McQueen's 930 slate gray it's a 356 color. Glasurit 615 Slate Gray.
1981 911SC Targa
Old 05-27-2017, 06:33 AM
Does that mean I need to purchase the paint from Glasurit? Sorry for the ignorance… I just want to make sure to get this right.
Old 05-27-2017, 07:52 AM
The Mighty Pieholio
Bob Kontak's Avatar
It means that Glasurit 615 is a different color than Glasurit 6801.
Glasurit is your source color. The factory paint starting point. You do not have to buy Glasurit paint.
You want to find the PPG mix/blend that is the same as Glasurit 6801. You are asking no more than that, correct?
If you HAPPEN to be wanting the Steve McQueen 1976 930 Slate Gray it's Porsche 356 Glasurit 615. That's all I am saying. There is probably a PPG formula for that somewhere.
1981 911SC Targa
Old 05-27-2017, 08:05 AM
That is exactly what I'm asking, Bob. Thank you for articulating it. I like the Porsche 6801. I've been searching for it and haven't been able to find any PPG formula.
Old 05-27-2017, 12:14 PM
Occasional User
You might try posting in the Paint & Bodywork forum. Porsche962 is a guru, he may know. Although I seem to recall he is not a fan of PPG. Just an idea.
Vince
2005 997S Silver Coupe, Black
1989 911 Silver Coupe, Silk Grey - sold
2009 Cayman S White, Full Cocoa - sold
1972 911E Silver Coupe, Pepita & Black - sold
Old 05-27-2017, 12:47 PM
The Mighty Pieholio
Bob Kontak's Avatar
Don't mention Sikkens either.
1981 911SC Targa
Old 05-27-2017, 12:51 PM
Thanks for the tip. Will do!
Old 05-27-2017, 01:10 PM
Good luck getting that color. I had three differant paint suppliers try and make it with PPG and none of them looked right. I was building a hot rod and it was for the bumpers only so I lived with it. But they all had a hard time trying to convert the formula.
78 911 st backdate
87 944
Old 05-27-2017, 04:02 PM
The Mighty Pieholio
Bob Kontak's Avatar
No one wants to do other than BC CC.
If it's not a show car BASF LIMCO is an option.
BASF also has a single stage urethane that can be matched to 6801. This is in the Glasurit family.
1981 911SC Targa
Old 05-27-2017, 04:39 PM
Thanks all. I'll look at something other than PPG.
Old 05-27-2017, 07:15 PM
Engine Case Guy
Try paintref.com
Color Codes - Slate Gray Paint Cross-Reference
Current: 1970 914-6 conversion 2.7, 1973 T, 1975 930 Turbo Targa, 1978 928 Race car, 6.57L, 1983 911SC, 1987 928S4 5 speed, 2002 911 Targa, 2007 997TT, 2009 997TT, 2004 40th Anniversary Carrera, Mclaren 570S and 12C
Only reproduction 3.6 cases on the planet www.taorminaracingdesigns.com
Old 05-27-2017, 08:19 PM
Puma's Avatar
I tried to use PPG also. The local guy called PPG paint library guys and they said they couldn't do it.
2001 986 S
Old 05-28-2017, 06:11 AM
The Mighty Pieholio
Bob Kontak's Avatar
Actually the two paint brands are RM and Glasurit. They are both owned by BASF. Both German.
Edit: OP posted in Paint and Bodywork forum. http://forums.pelicanparts.com/paint-bodywork-discussion-forum/958174-6801-paint-code-formula.html
1981 911SC Targa
Old 05-28-2017, 09:33 AM
