Evaluating valve adjustment time by sound
It's major-service time for my car, as there are a variety of things that it is due for, including an oil change. My valves were last adjusted 10,000 miles ago, on the day I picked the car up. I understand 10k-15k is the appropriate interval for checking the valves; I drive it about 4-5k per year.
In April I had an emergency brake caliper rebuild done by a good 911 mechanic in Nashville (Wicky Lawrie) as I was on my way to Atlanta. After pulling my car into the shop, he commented that the valves sounded a slightly noisy to him and it might be worth checking them. To his ear, one cylinder was also noisier than the rest. In his opinion it wasn't urgent, but he was picky enough about that that if it were his car he would do it because listening to it would annoy him. So as I prepare to put my car up on stands for a bit to change the oil, check the plugs, replace some fuel lines, rebuild the other front caliper, work on the pedal cluster, etc. I ask myself whether I should check the valves and adjust as needed. It will be my first time and I am not afraid of the task, but all the same, if I don't need to do it now I'd just as soon not. Partly because I'd have to order a gasket set and feeler gauges, etc. which means waiting another week. For all I know they're all within spec, just on the loose side (I recall the spec is .04 +/-.02, which is a pretty big range) Should I just do it, or is there any harm in waiting until my next oil change? I did take a video of the car idling that I will upload, though it may be a bit hard to hear the valves over the high idle (car is cold), fan and exhaust. |
They need to be at 0.004. If you can't pull that off pay your wrench. That said, clackity clack is better than silent. More rant: If by chance your 0.002 gap goes south to say -0.001, your valve does not close. Bad things. You are in Chicago. I say gear up for a winter project. Side note, I see pictures of donuts and beer being posted by Rawknees to discredit me. I do call the mega competent wrench, Rawknees, a pin head now and then. Order of magnitude? You decide. http://forums.pelicanparts.com/uploa...1497129655.jpg Go easy on him, I'm hanging with his Mom right now. |
Oh, don't blame likes-to-be-on-his-knees for it. For all I know I recall it from the manual, or a man i a trenchcoat in a parking garage at night. All the same, .004 +/- .001 is pretty different from, say, .004 +/- .0001. If I am a touch high, I'm not going to worry about it, even as I am going for .04 on all valves.
As for how they are now, as you say, clackity-clack is better than silent. I do not tend to slack on maintenance on my cars, but I don't want to do something unnecessary, either. As for winter projects, my unheated garage and my hands' intolerance for cold means nothing much gets done in winter unless it is unusually warm. |
Carv'in into Rawmeatrono Bob! Has serious ring to it.
Ott... I say if the other work is being done, why not check valves and get it done. Downstream you'll probably be glad you did it. |
http://forums.pelicanparts.com/uploa...1497131292.jpg |
He'll respond. Here's a recent pic of him after a haircut. http://forums.pelicanparts.com/uploa...1497131664.jpg |
Ha!
http://forums.pelicanparts.com/uploa...1497132079.jpg |
Cause you know you must be able to scratch things. |
http://img11.deviantart.net/4475/i/2...girlsuzy17.jpg PS - about the valve lash specs - ol' Bob doubted me about that in another thread, and I promptly pimp slapped him with a text pic of the factory spec sticker. https://ih0.redbubble.net/image.7309...01c5ca27c6.jpg |
I will learn you a thing or two about a thing or three, yet! And I say again ----> http://cdn.quotesgram.com/small/30/9...-Pimp-Slap.jpg ^^^ You're the one on the right! |
It is possible that a valve or two are now out of spec but these are not quiet engines.....and was said earlier, it is better for the valves to be too loose than too tight. It's your call but, I would adjust them on whatever schedule you choose. I personally do the 15k mile schedule as per my 3.2's original Porsche service record. Cheers
I was trained by Porsche and can say that they were specific about clearance. But not 0.004in, rather 0.01mm which is 0.0039 inch. Or a "tight" 0.004 inch.
So how does one explain the engine decal stating a range? Well, Porsche is a small company and I've found they often have (gasp) some disagreement about the details. The 0.01mm needs to be exact when assembling an engine with new or refaced components. I have measured these a few days later after just a few miles and yes they will be different from what they were set at. So my belief is that a range is okay and looser is better than too tight. You have to be careful with turning the engine over with removed plugs since carbon fluff can get between valve and seat throwing off measurement. |
Yes looser is better than too tight, because if they are too tight, they won't seal properly or long enough, and that is how you burn a valve. Run a burnt valve long enough, and you will eat a valve. Eat a valve, and things get very expensive.
Some people say a tappy engine is a happy engine. It turns out that the tighter they are, the quieter they get, so setting them too tight and having a nice quiet engine is a no no. Over time, you would think maybe the stem would wear, and things would get looser, but if the valve starts to wear into the seat, things will actually get tighter, and this is why you need to check them. If you don't know with certainty when the last valve adjustment was performed, you need to check it. |
Thanks for all the feedback. And the Bob & Ronnie show is, um, entertaining :) I think I'll just leave them be for another oil change unless I feel compelled for some reason to drain the oil and check them this winter.
I said, Jeebus, look at that thing it's perfect. Please climb down off of my back right now. She said, no, it's great, it's just that his Dad used to call him bubble head. They were tears of joy. |
Mom holdin' the ol' Stones for you afterwards, too, and s**t! <iframe width="854" height="480" src="https://www.youtube.com/embed/7tzc-dB8Xuk" frameborder="0" allowfullscreen></iframe> |
valves tend to get tighter over time.
you did not say how many mile are on the engine, I would also look for other signs. does it smoke when you first start it up. if so you could be looking at a guide issue, I know on my worn out 77s motor the "valves" where noisy after an adjustment, perhaps guides where worn out or something else in the valve train., I just kept driving it. |
T77911S,
The PO had the engine rebuilt (he did some of the work himself) in 2010, and the top end was redone in 2013 because somehow the exhaust-side valve guides were missed the first time. It saw probably a couple thousand miles between then and my buying it in 2015, and I've put 10k on it since then. So all in all, a pretty fresh engine. 89k on the odometer but the speedo is non-original so it is TMU. The above-mentioned mechanic mentioned to me that, based on his ear hearing one cylinder that seemed louder than the others, that in addition to simply a slightly loose valve it was possible that the rocker shaft on one cylinder was slightly out of position (he showed me the right and wrong positions on a disassembled head in the shop, and told me how that mistake can happen) and worth inspecting for when I had the covers off. I think it smokes a little on first startup (I find it hard to notice) but nothing abnormal, given that it has been sitting for at least a week. |
