scottb's Avatar
Question What are factory shop manuals worth?
I have a line on volumes 1-4 of the factory shop manuals for my 84 Targa. What are these worth?
Also, I always thought the set was 5 volumes. Am I correct? If so, what's in volume 5 (the seller says volume 1 is engine, 2 transmission, 3 chassis, heating and a/c, and 4 body and electrics)?
Thanks for the help.
1984 Targa
Old 01-31-2003, 09:39 AM
Irrationally exuberant
ChrisBennet's Avatar
Volumes V Wiring '87 on. My earlier manuals ('72 on) have 4 volumes. Make sure you are getting the "Carrera" manuals.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 01-31-2003, 10:36 AM
scottb's Avatar
Chris: Do you think the set for 84 only has 4 volumes? What's the set of 4 worth used? Seller says very good condition, with some smudges.
1984 Targa
Old 01-31-2003, 10:39 AM
I'm drawing a total blank on what's in each binder, but I have 4 red, 2 silver and a turbo supplement for my '79
Charlie Baer
'79 Euro 911SC (Guards Red)
'83 Quattro (Mars Red)
Old 01-31-2003, 10:41 AM
Hilbilly Deluxe
emcon5's Avatar
Looks like 5 volumes for the 84-89 cars.
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_documt_pg1.htm
They are on perpetual backorder though.
Tom
82 911SC Coupe
GTI Cup #43
Old 01-31-2003, 10:48 AM
scottb's Avatar
What's in volume 5?
1984 Targa
Old 01-31-2003, 10:57 AM
Here's the poop:
Vol 1 and Vol 2 (large!)...for 1965 through 1971
Vol 3 through 6 ( 4 volumes)...1972 through 1983
Five volume "Carrera" set ( 1984-89) ...at first was a four volume set.
New...from places like "MY" Porsche...about $190 for both 1 and 2
...about $400 for vol 3-6...about $400-$500 for Carrera 5 volume set...or close to $1000-$1100 for the 11 volume set.
Still trying to sell my 1972-83 repro Xerox set (one set only!), used as a "clean" set with no fingerprints.
--Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 01-31-2003, 11:55 AM
scottb's Avatar
. . . at first was a four volume set
Wil: Did the four volume set expand to five volumes? In other words, did they take some subjects out of the first four volumes, and put them into a fifth volume?
I just want to be sure I have everything I need in the four volumes.
Thanks.
1984 Targa
Old 01-31-2003, 12:19 PM
ScottB:
Bruce Anderson's first book identifies the Carrera set as a four volume set...and his later revision to his performance book calls this out as a five volume set. I've always seen it as a 5 volume set, myself.
--Wil Ferch
Wil Ferch
Old 01-31-2003, 12:21 PM
Oh, another thing....
from the way the 5 volume set is packaged, I'd imagine that the last volumes ( electrical? as I recall) may have simply added the diagammatics of the later build-years...I don't know, as I've never seen a 4 volume set. Plus, to get the real info you need, you would be best off using the entire 11 volume set, as the later volumes build upon the early versions. Get the Bentley manual , too, and you'll likely be all ( mostly) set.
--Wil Ferch
Wil Ferch
Old 01-31-2003, 12:25 PM
scottb's Avatar
It's far too complicated...and expensive (I think). I'll stick with 101 Projects and Bentley. Anything beyond that will probably go to the "wrench." Thanks.
1984 Targa
Old 01-31-2003, 12:30 PM
